Find the maximum height and the range of the ball.
The problem involves calculating the maximum height and range of a ball kicked on the moon, where the acceleration due to gravity is given as 1.62 m/s². The original poster notes a lack of information regarding the initial velocity required for the calculations.
  • Exploratory, Assumption checking
  • Participants discuss the necessity of knowing the initial velocity and angle to solve the problem. Some question whether all relevant information has been provided, while others suggest that ratios of range and height can be determined based on known values from Earth.
The discussion is ongoing, with participants seeking clarification on the initial conditions needed for the calculations. Some guidance has been offered regarding the relationship between the moon and Earth scenarios, but no consensus has been reached on how to proceed without the initial velocity.
There is an indication that the original question may reference external materials for context, and the initial velocity from a similar problem on Earth has been mentioned, but it is not explicitly provided in the current problem setup.
afcwestwarrior
The acceleration due to gravity on the moon has a magnitude of 1.62m/s^2. Assume that the ball is kicked on the moon instead of on the earth. Find(a) the maximum height H and (b) the range that the ballwould attain on the moon.
acceleration=1.62 m/s^2
H=?
R=?
Vy=0 m/s
Voy=?
H=-Voy^2/ 2(Ay)
Ok I have no Idea what the initial velocity is, so how can I calculate this problem.
Are you sure you've given all the information stated in the question?
Well here's the original question. Review Interactive Learning Ware 2.3 at www.wiley.com/college/cutnell in preparation for this problem. The acceleration due to gravity on the moon has a magnitude of 1.62m/s^2. Assume that the ball is kicked on the moon instead of on the earth. Find(a) the maximum height H and (b) the range that the ballwould attain on the moon.
then it says look at example 6-8 in your book. I know what equation to use, but the question only gives me gravity.
One would need the initial velocity and angle with respect to horizontal.
Otherwise one can only determine the ratios of R and H on the moon with respect to the corresponding R and H on earth, assuming the same initial velocity and angle.
Is there a reference to a similar problem on the earth?
ok in the examples the initial velocity of the football is 14 m/s on earth
  • · Replies 38 ·
