Local coordinates, physical coordinates
The discussion centers on the relationship between local coordinates and physical coordinates within the context of general relativity (GR). Participants clarify that coordinates are arbitrary numerical assignments to events in a manifold, lacking inherent physical significance. The essential requirements for valid coordinates are that they must smoothly map an open subset of the spacetime manifold to an open subset of R4 and be one-to-one. Understanding this concept is crucial for calculating metrics and geodesics in a laboratory coordinate system.
  • Understanding of manifolds and their properties
  • Familiarity with general relativity concepts
  • Knowledge of coordinate systems in mathematics
  • Basic grasp of metrics and geodesics
  • Study the properties of manifolds in differential geometry
  • Learn about the metric tensor in general relativity
  • Explore the concept of geodesics and their calculations
  • Investigate different coordinate systems and their applications in physics
Physicists, mathematicians, and students of general relativity seeking to deepen their understanding of the relationship between local and physical coordinates in spacetime.
mrandersdk
As far as I can understand space is af manifold with some metric on it. A manifold is described with some charts (coordinates), but how do I relate these coordinates with ex. physical coordinates of some particle.
Is it like this:
if I'm in some laboratory I make some cartesian coordinate system (x,y,z) (maybe include time (t,x,y,z)), so that I can say that my particle is at p_0 = (x_0,y_0,z_0). Then my task is to find the metric in my laboratory coordinate system, so I can for example calculate the geodesic for my particle. But p=(x,y,z) should be functions to my manifold, that is p: R^3 -> M, and how should they look.
As you might see I have a bit trouble understanding, how to relate the physical coordinates to the manifold, so that the description of GR becomes useful.
Hope someone can help me understand it. Thanks in Advance, Anders Berthelsen.
Well, the first thing is to realize that there is no such thing as “physical coordinates”. Coordinates are simply a smooth set of numbers assigned to events in the manifold. They are completely arbitrary and have no inherent physical significance.
Now, as to how you can assign coordinates, the answer is essentially any way you like. Coordinates have only two requirements: they must smoothly map an open subset of the spacetime manifold to an open subset of R4 and they must be one-to-one. Any method you devise that satisfies those two constraints is valid.
  • · Replies 40 ·
  • · Replies 26 ·
  • · Replies 22 ·
  • · Replies 20 ·
