Discrete Mathematics: Solving for x in a System of Equations
The problem involves a system of equations relating integers a, b, and c to nonzero real numbers x, y, and z through specific fractional relationships. The primary question is whether x is rational and how it can be expressed as a ratio of two integers.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss various algebraic manipulations and substitutions to isolate x. There are suggestions to multiply equations and take reciprocals to simplify the expressions. Some participants express uncertainty about the algebraic steps involved.
The discussion has seen attempts to clarify the relationships between the variables and explore algebraic transformations. One participant indicates a realization of the solution after the homework was submitted, suggesting that understanding has been achieved, though no explicit consensus on the method has been reached.
Participants note challenges with algebraic skills and the implications of the problem's requirements on rationality, as well as the timing of the homework submission affecting the discussion's outcome.
tennesseewiz
Suppose a, b, and c are integers and x, y, and z are nonzero real numbers that satisfy the following equations:
xy/(x+y)=a
xz/(x+z)=b
yz/(y+z)=c
Is x rational? If so, express it as a ratio of two integers.
I substituted a lot of equations and I know I need x to equal something. What I got was:
x= abcx/(acx+bcx-abx-abc)
However I don't know how to solve for x (my algebra skills suck... don't ask me how I made it to discrete mathematics...)
I know that if I solve for x, I can basically work out the problem on my own.
The equation with "c" in it relates "y" and "z", perhaps if you multiply the equation with "a" and the equation with "b" together, you could find some place to substitute some expression with "c" in for some combination of "y" and "z".
Take the reciprocal of both sides. The expression you will have on the right can be separated into four terms. The x will cancel out in the first 3 terms. In the 4th term abc will cancel out, leaving -1/x. Now add +1/x to both sides, you will have 2/x on the left. (On the right, -1/x will cancel out.) Then divide both sides by 2. Everything on the right are integers, which means 1/x is rational. If 1/x is rational, so is x.
Oh my gosh, thanks! It's sad that I got the answer now after I had to turn in my homework, but at least I understand it now! :D
