Free-Fall Motion (w/ a tennis ball)
The discussion revolves around a physics problem involving free-fall motion of a tennis ball dropped from a height of 4.00m, which rebounds to a height of 2.00m. Participants are exploring the average acceleration of the ball during its contact with the floor and whether this acceleration is directed upwards or downwards.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to calculate the average acceleration but expresses uncertainty about their approach, particularly regarding the time of contact and the direction of acceleration. Other participants question the method used to determine time and suggest alternative equations of motion to find velocities before and after the impact.
Participants are actively engaging with the problem, offering suggestions for different methods to approach the calculations. There is a recognition of potential misunderstandings in the original poster's reasoning, and multiple interpretations of the problem are being explored without reaching a consensus.
One participant notes the assumption of no air resistance, which may influence the calculations and results discussed.
Feldoh
To test the quality of a tennis ball, you drop it onto the floor from a height of 4.00m. It rebounds to a height of 2.00m. If the ball is in contact with the floor for 12.0ms, (a) what is the magnitude of its average acceleration during that contact and (b) is the average acceleration up or down?
Equations of motion w/ constant acceleration
I'm pretty sure (b) is up for starters since the ball reaches a height of 2m after it is on the ground which means it's got to accelerate up.
My problem is with part a. I started by figuring out the velocity of the ball the moment it hits the ground.
[tex]v = at[/tex]
[tex]v = \frac{y-y_o}{t}[/tex]
So substituting the second equation in the first one and solving for t:
[tex]t = \sqrt{\frac{y-y_o}{a}}[/tex]
[tex]t = \sqrt{\frac{-4m}{-9.80\frac{m}{s^s}}} = .64s[/tex]
Since I got the time...
[tex]v = v_{o}+at = 0 + (-9.80)(0.64) = -6.3m/s[/tex]
In my mind I thought that I had the initial velocity of the time interval it was on the ground and I thought that the final velocity would be 0 since if it was greater than 0 the ball would be traveling "up".
First I found the time in s and got 12.0ms = .012s, then:
[tex]a_{avg} = \frac{v-v_o}{t} = \frac{0-(-6.3)}{.012}[/tex]
My answer was a = 525m/s^2, but it's wrong -- my book says its 1.26*10^3 m/s^2
So uhh... where did I go wrong? XD
Oh don't think it would really matter at all in this problem but assume there is no air resistance.
How did you get the time? Try using [tex]s=ut+\frac{1}{2}at^2[/tex] and [tex]s=vt-\frac{1}{2}at^2[/tex]. Then applying [tex]v=\frac{y_1-y_o}{t}[/tex], find the velocity just before it hits and just after it rebounds, use [tex]a=\frac{(v-u)}{t_o}[/tex], remembering that one velocity vector points downward and the other vector points upward.
Whoops should have made it a bit clearer how I derived the time. I edited my first post.
But I really don't get what your saying to do...
Well, get two different veocities, by the first three equations, and use the fourth to find your acceleration.
  • · Replies 38 ·
  • · Replies 25 ·
12K
