Calculating Initial Speed: Solving for Vi in Projectile Motion
The problem involves calculating the initial speed of a ball thrown vertically, given its height at a specific time and the acceleration due to gravity. The context is projectile motion, specifically focusing on kinematics equations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss various kinematic equations to determine the initial speed, questioning the correct application of formulas and the interpretation of height and time. There are attempts to derive the initial speed using different approaches, including calculating final velocity and using displacement formulas.
The discussion is active, with participants exploring different equations and clarifying misunderstandings about the application of kinematic formulas. Some guidance has been offered regarding the correct form of the equations, but there is still uncertainty about the calculations and interpretations of results.
There is confusion regarding the maximum height and the correct use of time and acceleration in the equations. Participants are also grappling with the implications of negative values in their calculations.
anglum
Calculating Initial speed?
A ball is thrown straight up at ground level passes a height of 80.6m in 5.1s.
The acceleration of gravity is 9.8m/s squared. What was its initial speed? answer in units of m/s
What equation is the correct one to use to calculate this
I tried using the formula tup=viy/g
and i also tried doing it as a table... where i calculated the velocity at 5.1 secs to be 15.804 m/s... by dividing 80.6 by 5.1 seconds...
then by adding( since if i was going ahead in seconds instead of back) 9.8 to that speed at 4.1 secs and gettin 25.604 m/s since
and goin up thru till 0 seconds... to get velocity of 65.784
please help me get thru this... this is my last problem for the weekend
80.6 is not the maximum height. There's a kinematics equation you can use directly and solve for v1. Think about the equations you have at your disposal.
i know 80.6 is not the maximum height but I am guessin i cannto use the subtracting gravity from speed... so there is just one kinematics equation that i can use and plug in the data i have that will help me solve this
What is the equation you can use?
im not sure what equation i can use which i would plug in the 5.1 seconds and the 80.6m as well as the acceleration of gravity to get my initial speed... tehre is one that i can put all 3 into?
Yup there is. what are your displacement formulas?
what displacement formula let's me take into account gravity
so would the formula be
Vf=Vi + at
where i solve for Vf as 80.6/5.1? and plug the gravity into the equation for the value of A?
Vf=Vi + at
No it's a formula that has d... displacement
would it be... Vf squared = Vi squared + 2 A D
where Vf is equal to 80.6/5.1
A = -9.8m/s
D = 80.6 m
A = -9.8m/s
D = 80.6 m
Not that equation. The equation has vi, d, t and a. No vf.
damn i thought that was the it...
ok so my only other equation that i think is
D = (Vi t) + 1/2 a t squared
so D would = 80.6
a would equal -9.8
would both the t equal 5.1?
then solve for Vi to get the initial speed?
so D would = 80.6
a would equal -9.8
exactly.
ok however... if i solve for that i get the initial velocity to be negative?
that doesn't make sense
i get 80.6 = Vi(5.1) + 1/2(-9.8 * 5.1) squared
then i get
80.6 = Vi(5.1) + 1/2(-49.980) squared
80.6=Vi(5.1) + 1/2(2498.00)
80.6=Vi(5.1) + 1249
-1168.400 = Vi(5.1)
-229.098 = Vi
that does not seem right to me
then i get
80.6=Vi(5.1) + 1249
-1168.400 = Vi(5.1)
-229.098 = Vi
It should be:
[tex]\frac{1}{2}gt^2[/tex]
not
[tex]\frac{1}{2}(gt)^2[/tex]
only t is squared. not g.
or do i only square the time and nto the acceleration of gravity?
o sorry u posted faster that i typed that question
so is it (1/2g)(t squared)?
yup.
so would the initial speed be equal to 40.794m/s in this particular problem
exactly.
thank you very much i appreciate you takin the time to help me
that's what i got.
[tex]y=y_0+v_{0y}t+\frac{1}{2}gt^2[/tex]
[tex]v_{0y}=\frac{y-y_0-\frac{1}{2}gt^2}{t}[/tex]
You said "D = (Vi t) + 1/2 a t squared"
That does NOT give you "80.6 = Vi(5.1) + 1/2(-9.8 * 5.1) squared"
Do you see the difference?
D= vit+ (1/2)a t2
not "D= vit+ (1/2)(at)2"!
15K
