How Does a Manual Water Pump Work?
  • Context: High School
  • Thread starter Thread starter PortlandG
    Manual Pump Water
The discussion centers on the mechanics of manual or hand water pumps, exploring different types and their operational principles. Participants also consider modifications for specific applications, such as dispensing pre-measured amounts of water.
  • Exploratory, Technical explanation, Conceptual clarification
  • Some participants describe various types of hand pumps, including rotary (crank) types and squeeze pumps, highlighting their mechanisms of action.
  • One participant seeks clarification on a specific product and expresses interest in modifying it to dispense a precise volume of water.
  • Another participant explains the operation of a bellows-type pump, likening it to an accordion and detailing how it creates a vacuum to draw water.
  • Several methods for calibrating the volume dispensed per stroke are proposed, including adjusting the size of the bellows chamber, using insulation foam in an oversized unit, or implementing a mechanical stop to limit stroke travel.
Participants present multiple viewpoints on the mechanics and potential modifications of hand water pumps, with no consensus reached on the best approach for achieving the desired dispensing volume.
Limitations include the specific operational details of different pump types and the assumptions made regarding the modifications proposed by participants.
Individuals interested in mechanical engineering, DIY modifications, or those seeking to understand the functionality of manual water pumps may find this discussion relevant.
PortlandG
could anyone please tell me how a manual/hand water pump works?
thanks
Welcome to PF, Portland.
There are several different kinds of hand pumps. The rotary (crank) type is usually just a positive-displacement gear unit, similar to the oil pump in a car. The smaller ones that you squeeze produce a vacuum by squishing the air out (first squeeze) through a one-way valve, then sucking the fluid in through a different one-way valve. After that, the cycle is the same except that it's the fluid in the 'chamber' that gets squished out.
Thanks for your reply Danger,
Is that how this water pump works? http://www.foryourwater.com/mm5/merchant.mvc?Screen=PROD&Store_Code=FYW&Product_Code=P0100&Category_Code=FYWWP
I've been trying to figure it out for a while! I want to modify one to dispense pre-measured amounts of water, let's say only 100 ml with each pumping action!
From the outside, it would appear that it's a simple 'bellows' type, which is a variation on the 'squeeze' type. Think of it like an accordion. When you push down, the bellows collapse and force whatever is in them out through the one-way valve in the spout. When they spring back up, a vacuum is created which allows ambient air pressure to force liquid from the reservoir through the other one-way valve into the bellows chamber.
There are 3 ways that immediately come to mind for calibrating the amount pumped per stroke. One is to just make the bellows chamber the proper size to contain that volume. The second would be to use an off-the-shelf unit that's overly large and fill up the excess space with something like insulation foam. Third would be also with an oversized unit, but with some sort of mechanical stop to prevent full travel of the stroke.
  • · Replies 26 ·
9K
  • · Replies 18 ·
  • · Replies 117 ·
  • · Replies 17 ·
  • · Replies 30 ·
