Experimentally Verifying Photon Spin: Beyond Stern-Gerlach
The discussion centers around the experimental verification of photon spin, specifically addressing whether photons can be classified as spin 1 particles. Participants explore various methods of verification, including the implications of polarization and conservation laws, while also considering alternative theoretical frameworks.
  • Some participants question how to experimentally verify that photons are spin 1 particles, noting that the Stern-Gerlach experiment is not applicable due to photons not being charged.
  • There is a proposal that the electromagnetic potential could be modeled as a 2nd-rank tensor, leading to speculation about its implications for photon spin.
  • One participant suggests that conservation laws, particularly related to dipole transitions in atoms, provide evidence for photon spin, while others challenge this assertion.
  • Concerns are raised about the validity of using atomic transitions as evidence for photon spin, with some participants disputing the connection between selection rules and photon spin.
  • Discussion includes the nature of photon polarization, with references to circular and linear polarization, and the concept of mixed states in natural light.
  • Some participants express uncertainty about the implications of different theoretical models, such as the relationship between photon spin and graviton spin.
Participants do not reach consensus on the validity of using atomic transitions as evidence for photon spin. There are competing views on the interpretation of conservation laws and their implications for photon properties.
Participants express varying levels of familiarity with quantum mechanics and the implications of different theoretical frameworks, indicating a range of assumptions and interpretations in the discussion.
This discussion may be of interest to those exploring the experimental aspects of quantum mechanics, particularly in relation to photon properties and polarization, as well as those interested in theoretical physics and alternative models of electromagnetic phenomena.
jostpuur
I just realized I don't know a simple thing. How do you experimentally verify, that photons are spin 1 particles? At least you cannot do it with the Stern-Gerlach experiment, because photons are not charged. The polarization effect is usually somewhat identified with the spin, but is it really the same? How do you calculate the theory of polarization measurements from the quantum mechanical principles? I've seen only classical explanations.
Suppose I throw a wild idea, that the electromagnetic potential is a 2nd-rank tensor [itex]A^{\mu\nu}[/itex], and four component potential has worked as an approximation of this, because they both give the Coulomb's force similarly, and the weak magnetic effects are the same (hopefully, I'm not 100% sure). What's the experimental results that contradict this?
SG should work on photons -- it depends on the magnetic moment, not the charge. However, I don't know if the experiment can be done that way.
Does your wild idea have any predictions which are different from the usual models? If not, then occam's razor gets used on the extra components.
I haven't thought about this much yet, which of course makes this a bad post. But I thought I could use some information, before trying to calculate stuff.
The 2nd-rank potential would be analogous to the gravitation, so I might guess the photon would be spin 2 then, as the gravitons are. I haven't really solved angular momentum of 2nd-rank field with Noether's theorem yet, but I've heard that the spin 2 is the result.
Er.. shouldn't this be verified simply via conservation laws?
For example, the dipole transition in atoms that resulted in the emission of photons requires a specific selection rule as far as the change in the angular momentum quantum number between the initial and final state. Unless one doesn't believe in that conservation law, one already has the evidence that the emitted photon must have a spin angular momentum of 1.
Zz.
Zz.
mhh... okey then.
Hi everybody,
Can I ask about the photon spin. Photon as the theory has spin 1, in which -1 for left-circular polarization and +1 for right-circllar, but the spin 0 state data actually exists. So, the spin of photon in the ellipse polarization and linear polarization, and with natural light we can understand how? I hope you can help me and explain for its. Thank you very much!
raj07 said:
why is graviton said to have spin 2.
are you not familiar with forum behaviour?
i) first try to google it
ii) ask question ONCE
iii) don't ask new, unrelated questions in already existing threads.
ZapperZ said:
...shouldn't this be verified simply via conservation laws?
Zz.
Er...I don't think so. You would need to show that there is a particular transition which ought to otherwise occur, and the only reason it doesn't occur is because of spin conservation.
From what I know of thermal emmission, as long as a transition between two states has a net oscillating electric or magnetic moment, the transition will procede. Regardless of the net change of spin.
Er... that's what the selection rule is!
Zz.
katsiusa said:
Hi everybody,
Circular polarization just specifies a particular pair of basis vectors. Photon
polarization can be expressed wrt other bases, eg linear. The circular
polarization basis is convenient because those states are eigenstates of
the angular momentum operator. A linear-polarized state can be
regarded as a superposition of those two circularly polarized eigenstates.
"Natural" light (by which I presume you mean incoherent light from the sun,
or some other hot substance) needs to be described by a mixed state.
Cf. http://en.wikipedia.org/wiki/Mixed_state
See also "Stokes parameters",
http://en.wikipedia.org/wiki/Stokes_parameters
Jackson, "Classical Electrodynamics", also explains a bit more
about the relevance of Stokes parameters in measurements
of polarization.
HTH.
Zz.
I don't believe you can name a specific transition which illustrates your point.
I already had! Read the post that I made earlier!
Do you dispute this?
Zz.
Yes, I dispute the "evidence" part. I don't believe the transitions, say, of the Hydrogen atom prove anything about the spin of the photon. Is that what you're claiming?
Yes.
So you're claiming that the atomic spectrum, as described in standard QM, is wrong?
Zz.
If the standard QM is correct, the spin 1 of the photon is correct.
If we deny the spin 1 of the photon, we must insist other theories.
For example, in Sommerfeld's theory, the spectrum of the hydrogen (fine structure) is explained by the relativistic mass change (s and p orbital).
Later, in QM, using the selection rule (2S -- x -- 1S, 2P --O - 1S), the fine structure was explained by the spin-orbital interaction.
The energy difference between 2P1/2 and 2P3/2 state was accidentally consistent with the the energy difference by the relativistic mass diffference between S and P orbitals.
We are not arguing whether quantum mechanics is correct or not. The claim was made that you can find experimental evidence for the spin of photons in the thermal spectrum of hydrogen gas. I believe this is incorrect.
Zz gave a standard correct texbook argument, cf the wiki article on http://en.wikipedia.org/wiki/Selection_rule" , and this argument can also be found as an example in books like Sakurai's, near the discussion of Wigner-Eckart.
I know that you are incorrect. Open any QM text. You disputed what I said, which is right out of standard QM for a standard selection rule.
Based on the responses given by several others, and now based on the nature of YOUR responses, I believe this thread is now done.
  • · Replies 58 ·
  • · Replies 0 ·
