Elastic collision between neutrons and deuterons
The problem involves elastic collisions between neutrons and deuterons in the context of Canadian nuclear reactors using heavy water moderators. The original poster seeks to determine the speed of a neutron after colliding with a deuteron at rest, the kinetic energy after the collision, and the number of collisions required to reduce the neutron's speed significantly.
  • Participants discuss the application of conservation of momentum and energy in elastic collisions, questioning the implications of equal masses on the final velocities. There is an exploration of the equations governing the collision dynamics and the resulting speeds and energies.
The discussion is ongoing, with participants attempting to clarify the relationships between the masses and velocities involved in the collision. Some guidance on applying conservation laws has been provided, but there is no consensus on the interpretation of the results or the implications of mass equality.
There are assumptions regarding the masses of the particles involved, with some confusion noted about the mass of neutrons compared to deuterons. The original poster expresses uncertainty about the number of collisions needed to achieve a specific speed reduction.
Edwardo_Elric
Canadian nuclear reactors use heavy water moderators in which elastic collisions occur between neutrons and deuterons of mass 2.0u.
a.) What is the speed of a neutron expressed as a fraction of its original speed, after a head-on elastic collision with a deuteron which is initially at rest?
b.) What is its kinetic energy, expressed as a fraction of its original kinetic energy?
c.) How many such successive collisions will reduce the speed of a neutron to 1/6600 of its original value?
If the 2nd particle is at rest
[tex]V_{A} = \frac{m_{A} - m_{B}}{m_{A}+m_{B}}[/tex]* V2
[tex]V_{B} = \frac{2m_{A}}{m_{A} + m_{B}}[/tex]* V2
let n = neutrons , dn = deuterons
a.)
VnMn = MnVn2 + MdnVdn2
using equation above:
[tex]V_{n2} = \frac{2.0u - 2.0u}{2.0u+2.0u} V_{n}[/tex]
Vn2 = 0
b.) K2 = ?
since Vn2 =0
VnMn = Vdn2
K2 = 1/2 (2.0u)(Vdn2)2
K2 = u(Vdn2)^2 <<<< K equals velocity of deuterons squared times u
c.) (2.0)(1/6600Vn) =
3300 collisions
I honestly don't know about this
For an elastic collision one applies conservation of momentum and energy.
Intially, the deuteron at rest, Vd, is zero, so it has not momentum or KE.
The neutron will not lose all its energy or momentum, but will recoil 180°.
So write the momentum and energy equations and one should end up with
http://hyperphysics.phy-astr.gsu.edu/hbase/elacol2.html#c1
but i thought masses are the same:
which makes
v{initial speed of neutron} = (m1 - m2) / (m1 + m2) * V{final speed of deuteron}
equal to zero? and the deuteron goes to move which has a speed equal to the initial speed of neutron?...
which makes
deuteron has a mass of 2.0u. Neutro has a mass of 1.0u
