Solve Oscillation Problem: Find C Value to Avoid Oscillations
  • Thread starter Thread starter Petrulis
    Oscillation
The discussion focuses on determining the critical damping coefficient (C) necessary to prevent oscillations in a mass-spring system submerged in a viscous liquid. The damping ratio (dr) is defined as dr = C / (2 * sqrt(k * m)), where k is the spring constant and m is the mass. For no oscillation to occur, the condition C must satisfy is C >= sqrt(4mk). This conclusion is confirmed as correct based on the provided reasoning.
  • Understanding of mass-spring systems and their dynamics
  • Knowledge of damping ratios and their significance in oscillatory motion
  • Familiarity with the concepts of critical damping and overdamping
  • Basic proficiency in algebra and manipulation of equations
  • Study the principles of harmonic motion and damping in mechanical systems
  • Explore the effects of varying the damping coefficient on system behavior
  • Learn about the applications of damping in engineering, particularly in suspension systems
  • Investigate numerical methods for simulating mass-spring-damper systems
Students studying mechanical engineering, physics enthusiasts, and professionals involved in system dynamics and vibration analysis.
Petrulis
A spring (which tension is k) is connected with a body (which mass is m). The whole system is in viscous liquid. In this liquid frictional force is proportional to speed: F = -C*v. With what C value the oscillation won't happen?
The damping ratio is defined as dr = c / (2 * sqrt(k * m)). No oscillation will happen when there is critical damping dr = 1 or when there is overdamping dr > 1.
So: C >= sqrt(4mk);
Is the solution above right?
The reasoning is correct, but I haven't checked your formulae.
