Why Is My Calculation of the Dielectric Constant Incorrect?
The calculation of the dielectric constant for a dielectric material between two parallel plates with an area of 110 cm² and charges of 9.6 × 10-7 C results in a dielectric constant (k) of 2.3. The induced charge on each dielectric surface is calculated using the formula q' = q(1 - (1/k)), yielding a value of 5.4 × 10-7 C. The equations used include k = q/(E*A*ε0) and q' = q(1 - (1/k)). The discussion highlights the importance of correctly applying Gauss' law for non-conducting plates.
  • Understanding of dielectric materials and their properties
  • Familiarity with Gauss' law in electrostatics
  • Knowledge of electric field calculations
  • Proficiency in using fundamental equations of electrostatics, such as k = q/(E*A*ε0)
  • Study the application of Gauss' law for different geometries
  • Explore the properties and applications of dielectric materials in capacitors
  • Learn about the relationship between electric field strength and charge distribution
  • Investigate advanced topics in electrostatics, such as polarization and its effects on dielectric constants
Students in physics or electrical engineering, educators teaching electrostatics, and professionals working with capacitors and dielectric materials.
roro0505
the answer i keep getting is wrong ... help?
Two parallel plates of area 110 cm2 are given charges of equal magnitudes 9.6 × 10-7 C but opposite signs. The electric field within the dielectric material filling the space between the plates is 4.2 × 106 V/m.
(a) Calculate the dielectric constant of the material.
(b) Determine the magnitude of the charge induced on each dielectric surface.
k=q/(E*A*epsilon_0)
q'=q(1-(1/k))
k=q/(E*A*epsilon_0)
=9.6E-7/(4.2E6*110E-4*8.85E-12)
=2.3
q'=q(1-(1/k))
=9.6E-7(1-(1/2.3))
=5.4E-7
It is not clear but I suspect that these are non-conducting plates, in which case Gauss' law is:
[tex]\oint E dA = E2A = \frac{Q}{k\epsilon_0}[/tex]
AM
  • · Replies 17 ·
  • · Replies 21 ·
11K
