What kind of issues related to I/O does multiprogramming have?
  • Thread starter Thread starter Eus
    Issues
This discussion focuses on the challenges associated with I/O management in multiprogramming environments, particularly contrasting interrupt-driven I/O and Direct Memory Access (DMA) systems. It highlights that I/O devices vary significantly in speed and data handling, which complicates uniform management. Multiprogramming improves resource management by allowing processes to wait for I/O while others execute, yet it does not fully resolve I/O efficiency issues, especially concerning disk operations. The conversation emphasizes the importance of layered I/O software systems and buffering techniques to mitigate deadlocks.
  • Understanding of multiprogramming concepts
  • Familiarity with I/O management techniques, including programmed I/O, interrupt-driven I/O, and DMA
  • Knowledge of operating system architecture and layered software systems
  • Awareness of buffering strategies in process management
  • Research the differences between interrupt-driven I/O and Direct Memory Access (DMA) implementations
  • Study the role of buffering techniques in preventing deadlocks in multiprogramming
  • Explore layered I/O software systems and their architecture
  • Investigate current advancements in I/O device efficiency and performance
System programmers, operating system developers, and anyone involved in optimizing I/O management in multiprogramming environments will benefit from this discussion.
Eus
Hi Ho!
When someone would like to implement a multiprogramming in a computer system, what kind of issues related to I/O does he have to consider?
Is there any difference between the implementation of multiprogramming in the system that uses interrupt driven I/O and the system that uses DMA?
I have never done any system programming so that I don't have any clue about the issues related to I/O in implementing multiprogramming. So, pointers to other resources would be very helpful.
Thank you.
Regards,
Eus
Computer science news on Phys.org
In general, it is well known that I/O management can be one of the messiest aspects of an operating system. I/O devices can be of various kinds i.e. either human readable (e.g. printers) , machine readable (e.g. disks, sensors)or for communication purposes (e.g. wired or wireless modems of various sorts, home routers etc.). All these devices are different in terms of data rate, unit of transfer (streams of bytes or blocks of characters), data representation etc. So, it is difficult to develop some uniform and consistent theory which covers every case and aspect. Also, as is widely known, the ways we can do I/O are programmed I/O, Interrupt-driven I/O and Direct Memory Access (DMA). Each of these has advantages and drawbacks depending on various factors.
I/O often forms a bottleneck in a computer system as I/O devices are slow (or very slow) compared with processor and main memory. One solution is multiprogramming, as it allows some processes waiting for I/O while others are running. So, we have a more efficient management of resources, but alone does not solve the above mentioned problem. There are still issues to be solved regarding the I/O efficiency. Disk operations is one very important of them.
During the years, I/O devices have become - and of course still do, faster and more efficient but an also important issue is providing a uniform and efficient way in handling them. One good strategy for this is hiding most of the details of device I/O in lower-level routines, so that processes and upper levels see devices in general terms such as read, write, etc. So, a layered I/O software system can serve this purpose, having layers (top to bottom): I/O user-level software, OS software (device independent) , Device Drivers, Interrupt Handlers, Hardware.
Also, buffering (single or double) is an important technique in order to avoid deadlocks among processes.
Now, above, I just briefly described a strategy for a system using interrupt driven I/O. For a system using DMA things go in a different way, as DMA module utilizes the system bus in order to transfer data and suspends the processor at some point. The net effect is delaying the processor to some degree. The importance of this effect really depends on the quantity of data, as for a multi-word transmission, DMA is far more efficient than interrupt driven I/O. But on the other hand, given today's very fast processors with multi cores, extremely efficient pipelining they are using etc., interrupt-driven I/O is far less of an issue than it was in the past.
There is a plenty of resources all over the net about multiprogramming in operating systems, which can be very easily found through google.
  • · Replies 19 ·
  • · Replies 45 ·
