The maximum and minumum Current
  • Thread starter Thread starter POLISH_Soldier
    Current Maximum
The discussion focuses on calculating the maximum and minimum currents for a resistor with a color code of red, red, orange, and gold, indicating a nominal resistance of 22,000 Ohms with a tolerance of ±5%. Using Ohm's Law, the maximum current measured with a 16V source is 0.69 mA, while the minimum current is 0.76 mA. The calculations confirm that the resistance values are correctly derived, and the provided resources for resistor color code calculations are deemed useful.
  • Understanding of Ohm's Law (V = IR)
  • Familiarity with resistor color codes
  • Basic knowledge of electrical resistance and current measurement
  • Ability to perform calculations involving percentages
  • Learn how to calculate current using Ohm's Law in different circuit configurations
  • Explore resistor color code calculators for quick reference
  • Study the effects of tolerance on resistor values in practical applications
  • Investigate the implications of using different voltage sources on current measurements
Electronics enthusiasts, electrical engineering students, and hobbyists looking to understand resistor calculations and current measurements in circuits.
POLISH_Soldier
A resistor has the following color code red, red, orange, gold. Determine the maximum and minimum currents, in mA, you should expect to measure when a 16 V source is connect across the resistor.
I dnt no if this is right...
22000 Ohms +- 5%
22000 + 5%= 23100ohms--->23,1K MAX
22000 - 5%= 20900ohms--->20,9K MIN
Now i dnt no if the following is good. Since I am using a 16V source i have to Use ohms law?
and what i got for both is a
-maximum of 0.69mA
-Minimum of 0,76mA
22000 Ohms +- 5%
Red = 2, so Red Red is 22.
Orange = 3, so the multipliyer is 1000 or 103,
and the nominal resistance is 22000 Ohms. or 22 kOhms.
the tolerance band is gold, so +/- 5%
Use V/R to get I, and min I = V/ max R.
This is useful - http://www.uoguelph.ca/~antoon/gadgets/resistors/resistor.htm
so is this - http://www.csgnetwork.com/resistcolcalc.html
Thx that's what i had and it seems right :) thanks again
  • · Replies 36 ·
  • · Replies 34 ·
