Muon Attenuation: Is Heavy Metal Significant?
  • Context: Graduate
  • Thread starter Thread starter stakhanov
    Attenuation Muon
The discussion revolves around the attenuation of muons as they pass through various materials, specifically focusing on the significance of heavy metal in comparison to concrete and magnesium. Participants explore the energy thresholds required for muons to traverse these materials and the implications for muon flux.
  • One participant notes that the minimum energy for a muon to pass through concrete is about 1.82 GeV, while for magnesium it is 2.7 GeV, and for a small piece of heavy metal, it is 0.13 GeV. They question whether the attenuation due to heavy metal will be significant compared to concrete and magnesium.
  • Another participant suggests consulting external resources for equivalent data on different materials, indicating the importance of material properties in the analysis.
  • A participant mentions having already calculated stopping power and radiative loss data for the materials in question and seeks clarification on whether the minimum energies can be simply summed to determine the total energy required for a muon to pass through all materials.
  • One participant recalls a method of treating the problem as a series of sequential regions, where the energy of the muon is calculated at the interface between different materials, suggesting a more detailed approach to the problem.
  • Another participant agrees with the sequential approach and discusses the muon energy spectrum, proposing that as muons lose energy, the spectrum shifts but retains its form, which may support the idea of summing minimum energies across materials.
Participants express varying approaches to the problem, with some advocating for a sequential treatment of energy loss while others consider the possibility of summing minimum energies. There is no consensus on the best method to analyze the muon attenuation through the materials.
Participants mention specific energy values and properties of materials, but the discussion does not resolve the assumptions regarding the applicability of summing energies or the treatment of energy loss across different media.
stakhanov
I am looking at muons being lost as they travel through a concrete bunker (with various things inside). The minimum energy (mean) for a muon to go through the walls is about 1.82GeV, and for the stuff inside (flakes of magnesium) it is 2.7GeV. For a piece of heavy metal it is 0.13GeV (it's only a small piece). The mean muon energy in the spectrum is ~6GeV.
I want to know whether the attentuation due to the heavy metal is going to be noticeable or if it will be lost amongst the attenuation due to the concrete and magnesium (I have a feeling it won't but I need to prove it).
Can you just add the energies and say that for a muon to pass through them all it must have above 4.65GeV? If so then if the heavy metal is not there (reducing the energy needed to 4.52) there probably isn't going to be a significant difference in flux.
Is there a better way of going about this?
See if this helps.
http://mightylib.mit.edu/Course%20Materials/22.01/Fall%202001/heavy%20charged%20particles.pdf
One needs to find the equivalent data for different Z materials as shown in figure 1 for water.
Thanks for the reply. I do have the equivalent data for the various materials I'm looking at. I have worked out stopping power. I have radiative loss data (enough to work out the linear approximation for energies above the muon critical energy) for all the materials. I have range as a function of energy for all the materials (from which I have the minimum energy needed to pass through a material of a particular thickness).
What I really need to know is whether I can just add these minimum energies (for a series of different media in a line) and say that the sum of the minimum energies is the energy a muon must have in order to get through them all.
I seem to remember that the treatment would be essentially a set of sequential problems, that is, one has 3 regions with different LET's. One simply solves for slowing down in the first region to get the particle (muon in this case) energy at the interface between regions 1 and 2, then solve for the slowing down through the second region and use the energy at the interface of regions 2 and 3, and then solve for the slowing down in the third region.
Is that what one is asking?
Yeah that's what I am after pretty much.
The number of muons at a specific energy is described by a spectrum (which is dependednt on what angle they arrive from the zenith). I figured that because the dE/dX is pretty flat between 1-100GeV (it's about 2MeV/g cm^2), then as muons lose energy through the medium, the spectrum (between 1-100GeV) will just shift down to a lower energy but keep the same form roughly. So muons with energy E1 are attenuated out and muons of energy E2 (where E2>E1) lose energy to become the new E1 muons and so on. If this is true then I think it must be ok to add the minimum energies for all the materials.
Thanks for your replies.
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 62 ·
13K
  • · Replies 19 ·
11K
