Making a Floating Lantern: What Should You Consider?
  • Thread starter Thread starter wisdom32
    Floating
To create a floating lantern, the primary consideration is ensuring that its total weight is less than the weight of the air it displaces. The envelope's weight and volume are straightforward to measure, while the weight of the hot air inside is temperature-dependent. At room temperature, 24 liters of air weighs approximately 29 grams, and this weight decreases linearly with absolute temperature. Experimentation is necessary to determine the average temperature of the air inside the lantern.
  • Understanding of buoyancy principles
  • Basic knowledge of thermodynamics
  • Familiarity with measuring volume and weight
  • Experience with hot air balloon mechanics
  • Research buoyancy calculations for hot air balloons
  • Explore the effects of temperature on air density
  • Learn about materials suitable for lantern construction
  • Investigate existing designs and experiments with floating lanterns
Hobbyists, engineers, and anyone interested in creating floating lanterns or experimenting with buoyancy and hot air balloon principles.
It simply has to weigh less than the volume of air it is displacing.
The weight and volume of the envelope are simple to measure.
The weight of the hot air inside will depend on the temperature, at room temp 24litres of air weighs around 29g it decreases linearly with absolute temperature ( ie deg C + 273)
You will have to experiment to work out how hot the air is on average - or find a site on make model hot air balloons
  • · Replies 18 ·
  • · Replies 18 ·
