Hertz Contact Stress: Calculating & Comparing Allowable Stress
The discussion revolves around the calculation and comparison of allowable stresses related to Hertz contact stress in cylindrical components. Participants explore the appropriate stress metrics for comparison, particularly in the context of cyclic loading and potential failure modes.
  • One participant calculated contact stress using the Hertz contact formula but is uncertain about which allowable stress to compare it against, mentioning material bearing stress and seeking guidance.
  • Another participant notes that contact stresses are often cyclic and that crack formation is a primary concern, suggesting that maximum shear stress could be a relevant comparison.
  • A different participant emphasizes the complexity of contact problems, indicating that yield conditions like von Mises stress might be useful for general assessments, while cautioning against overly simplistic approaches.
  • One participant recalls the existence of tables or simplified formulas for under-contact shear stresses and tensile stresses at the edge of contact, suggesting these might be useful for practical applications.
Participants express differing views on the appropriate stress comparisons and the complexity of contact problems, indicating that multiple competing perspectives remain without a clear consensus on the best approach.
Participants highlight the need to consider various factors such as cyclic loading, surface failure mechanisms, and the limitations of simplified models when assessing contact stresses.
har_rai
HI All:
Using Hertz contact formula I calculated contact stress for cylinder in contact with cylinderical socket but I don't know to which stress to compare this contact stress.Actally I comapred with material bearing stress & calculated stress was less that bearing stress(got margin of saftey 2), but I am not sure whether to comapre this with the baering stress so please some body tell me to which allowable stress to compare this contact stress.
Well to calculate the Hertz conatact stress i used the folowing formula.
stress=.591*SQRT(p*E/Kd)
And if I want to compare hertz stress with shear stress what wold be the relation between two.
thanks
The concern with contact stresses like this is that they are usually cyclic and thus you don't run into the typical tensile test failure modes. Whenever we talk about Hertz stresses like this, we are usually looking at our bearings. In these cases, the loading is such that crack formation is usually the main concern. To top it all off, if you ever get a chance to look at some of the theory, if you take two spheres and load them, the contact pressure is not the highest stress to be found. The higher stress levels are below the surface. This makes crack detection a lot tougher because it necessitates x-ray inspection.
As a starting point, if you really want to have a number to compare against, I would start with the max shear stress as a comparison. Again though, you do have other areas you need to address as well. Good luck.
yeah, before you use anything to make a conclusion you really need to think about what you're trying to accomplish. Contact problems usually involved a whole lot more than a single quasi-static loading of a simple geometry (like if the word 'wear' comes up the situation can become really complex). But if you're after just seeing how you situation generally 'is' with respect to yield, using typically yield conditions (von Mises stress and alike) is one way to go (and perhaps the first). In a specific application a lot can be said from the value of the contact pressure itself (using engineering tools and methods for that application assuming a certain pre-existing situation). Just make sure if you're actually trying to get to the failure of the surface you don't take too simplistic of an approach (take a look at any tribology/wear book and the number of mechanisms for surface failure and what different issues affect them ---> lots of different criteria and models utilizing different measures of stress, deformation, material properties etc).
Welcome back Perennial! Long time no see.
Thanks Fred! Works does "funny" things occasionally :wink: .
I think have seen somewhere along with contact pressure solutions tables/simplified formula for under the contact shear stresses (along with at the edge of contact tensile stress). Such might be usable in this case if want to get results without dwelling on the problem too much (simplified that is). Not sure if Roark having a basic collection of Hertz cases has anything such though, don't think too extensively at least (might be that am remembering some articles and such).
