AD9959 PCB Footprint Import for ExpressPCB Layout - Tips and Resources
  • Thread starter Thread starter Jdo300
    Pcb
The discussion focuses on creating a PCB footprint for the AD9959 chip in ExpressPCB. The user initially sought an importable footprint from Analog Devices but found none available. After considering the dimensions from the datasheet, the user successfully created the footprint and shared it for others to use. This highlights the importance of utilizing datasheet measurements when suitable footprints are unavailable.
  • Understanding of PCB design principles
  • Familiarity with ExpressPCB software
  • Knowledge of chip datasheets and specifications
  • Experience with footprint creation for electronic components
  • Research how to create custom footprints in ExpressPCB
  • Learn about the AD9959 chip specifications and requirements
  • Explore best practices for PCB layout design
  • Investigate alternative PCB design software that supports footprint imports
PCB designers, electronics engineers, and hobbyists working with the AD9959 chip or using ExpressPCB for their layouts.
Jdo300
Hello All,
I'm working on a PCB layout in ExpressPCB and I am trying to make a footprint for the AD9959 chip.
I went to this page here on Analog Devices' page to get a suitible pcb footprint but they don't have any formats that I can import into ExpressPCB: http://www.analog.com/en/SymbolsAndFootprints/0,3152,AD9959,00.html
Originally, I was just going to take the measurements from the datasheet to make the pads but I'm not sure how big the heat pad should be or of some of the exact dimensions for the positioning of the pads. I figured it would be safest to just import one that was already designed to minimize the possability of any issues later.
Do any of you know of any CP-56 footprints that I can look to for reference dimensions or one that can be imported into ExpressPCB?
Thanks,
Jason O
Ok, nevermind. I managed to make the footprint from the measurements in the datasheet. Here is a copy of it in case anyone else out there may want to use it.
- Jason O
  • · Replies 55 ·
11K
  • · Replies 16 ·
