Calculating the Free Fall of Two Balls
The discussion revolves around calculating the time it takes for two balls to fall from a height of 5 meters under the influence of gravity, using an acceleration of 10 m/s². The original poster expresses uncertainty about how to begin solving the problem.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the effects of neglecting air resistance and the constant acceleration of the balls. There are questions about the appropriate equations to use for calculating the time of fall and the relationship between distance, acceleration, and time.
Some participants have provided references to external resources that may assist in understanding the concepts involved. The original poster has made an attempt to apply a formula but expresses confusion about the calculations, indicating an ongoing exploration of the problem.
The original poster has not attempted a solution initially and is working under the constraints of a homework assignment, which may limit the resources they can consult.
Robdog
Two ball are dropped from 5m high, Use 10 m/s^2 for the magnitude of the acceleration due to gravity.
How do i start?
not sure on how to start so i haven't attempted:(
the problem asks how much time is elapsed during the fall of the 5.0m at a rate of 10m/s^2
Im sure there is an equation for this but i don't know which one or where to find it...
If something starts at rest, i.e. with zero velocity, how far does is travel in time, t, if the acceleration is constant.
See - http://hyperphysics.phy-astr.gsu.edu/hbase/acons.html
The same concept applies for horizontal (x) or vertical (y) motion, provided the acceleration is constant.
so... y=1/2at^2... y equal to the height of 5m? if so then i get 5m=1/2(10m/s^2)T^2 which = square root of 5.00s which = 2.24s? but the that answer is still wrong. What did i do wrong.
o nvm should be the square root of 1.00s... ill try that, wow i feel like an idiot... i need to sleep
Well - you figured it out. Do get some sleep, and refer to hyperphysics when the mind is more relaxed.
  • · Replies 31 ·
