| Thread Closed |
[SOLVED] Limits |
Share Thread | Thread Tools |
| Sep25-07, 08:18 PM | #1 |
[SOLVED] Limits
I have two...
1. The problem statement, all variables and given/known data The the limit 2. Relevant equations [latex]\lim_{x \rightarrow 1} \frac{1-cosx}{x^2}[/latex] 3. The attempt at a solution I figured to just plug in 1, but I wanted to make sure.... 1. The problem statement, all variables and given/known data Find the limit 2. Relevant equations [latex]\lim_{x \rightarrow 3} \frac{\sqrt{x^2-6x+9}}{x-3}[/latex] 3. The attempt at a solution I plugged in the 3, and got 3/0, then I got lost... |
| Sep25-07, 09:31 PM | #2 |
Recognitions:
In 2, did you try simplifying the numerator? (What are the roots of the polynomial?)
| Sep26-07, 12:22 PM | #3 |
Yes, I tried doing that.
[latex](x-3)(x-3)[/latex] However, I forgot how to get rid of that radical. Squaring wouldn't work, so I have no idea. Also, no thoughts on the first one? |
| Sep26-07, 12:24 PM | #4 |
Recognitions:
[SOLVED] Limits
What is a short hand expression for (x-3)(x-3)?
| Sep26-07, 12:29 PM | #5 |
(x-3}^2. Oh yeah, so that takes away the square root, and after everything, it leaves 0. thank you.
| Sep26-07, 12:41 PM | #6 |
Recognitions:
In the first one, are you sure the problem isn't x->0 instead of x->1 ?
| Sep26-07, 12:51 PM | #7 |
it is 1, not 0.
| Sep26-07, 12:55 PM | #8 |
Well, then your book has a typo..
| Sep26-07, 12:58 PM | #9 |
it's not from my book, it was my teacher.
| Sep26-07, 01:01 PM | #10 |
Recognitions:
Well, it's 99% certain that your teacher meant to write 0 instead of 1. With 1, it's trivial, since both the numerator and denominator are finite, nonzero constants in that limit.
| Sep26-07, 01:01 PM | #11 |
Then he either blundered, or tried to fool you.
Your function is defined&continuous on all values of x except x=0. Your original approach is perfetly valid in the case of x=1. |
| Sep26-07, 01:06 PM | #12 |
allright, thankyou.
| Thread Closed |
| Thread Tools | |
Similar Threads for: [SOLVED] Limits
| [SOLVED] Calculus: Limits | Calculus & Beyond Homework | 4 | ||
| [SOLVED] Factorial Limits | Calculus & Beyond Homework | 7 | ||
| [SOLVED] One-Sided Limits | Calculus & Beyond Homework | 5 | ||
| [SOLVED] limits of integration | Calculus & Beyond Homework | 6 | ||
| [SOLVED] Limits Question | Calculus | 9 | ||
