Electric and magnetic fields question
The discussion revolves around the motion of a charged particle in uniform electric and magnetic fields, both directed along the z-axis. Participants are exploring the implications of these fields on the particle's trajectory and the equations governing its motion.
  • Participants are attempting to resolve the equations of motion into their components and are questioning how to integrate the effects of both electric and magnetic fields. There is discussion about the nature of the trajectory under the influence of these fields and how to combine the equations for x and y components.
Some participants have provided guidance on resolving the equations and integrating them, while others express uncertainty about combining the x and y components. The discussion is ongoing, with various interpretations and approaches being explored.
There are constraints regarding the assumptions made about the fields and the conditions under which the particle is moving, including the neglect of relativistic effects. Some participants are also addressing the need for clarity on the definitions of electric and magnetic fields.
Oblio
A charged particle of mass m and positive charge q moves in uniform electric and magnetic fields, E and B, both pointing in the z direction. The net force on the particle is F=q(E+v x B)*. Write down the equation of motion for the particle and resolve it into its 3 components. Solve the equations and describe the particles motion.
Since there are both electric and magnetic fields, should I consider the motion with respect to each individually?
Considering the Electric field, the trajectory is a straight line along z, since its parallel to E, and a parabola along x,y? Yes?
The Magnetic field will have a force perpendicular to both v and B right?
Now, how does one put the two together?
*Is v (cross) B, x is cross product not a variable.
I need help on this physics question:
An electron is shot at 10^6 ms-1 between two parallel charged plates. if (e) = 1 KN/C where will the electron strike the upper plate? Assume vacuum conditions.
Rather than conceptually deducing the particle's motion, it'd probably be better to write down what F_x, F_y, and F_z are (the three components of F) with respect to E_x, E_y, E_z, B_x, B_y, B_z, v_x, v_y, and v_z. At this point a lot should cancel since only E_z and B_z are nonzero.
Use the force, Luke. Ignoring relativistic effects,
[tex]m \mathbf{\ddot{x}} = \mathbf{F} = q\left(\mathbf{E} + \mathbf{v}\times\mathbf{B} \right)[/tex]
Resolving the components, [tex]\mathbf{x} = (x,y,z)[/tex], and using the fact that only the z-components of E and B exist:
[tex]\begin{align*}<br /> m \ddot{x} &= q \left( v_y B_z \right) \\<br /> m \ddot{y} &= q \left( -v_x B_z \right) \\<br /> m \ddot{z} &= q E_z<br /> \end{align*}[/tex]
You should now be able to solve for z, at least. Combine the equations for x and y to get a 3nd order equation for x, or 2nd order equation for [tex]\dot{x}[/tex].
lol :)
Can't you just integrate for each separately? I don't know you would put x and y together.
After you have each, what is 'solving' them, as asked in the question?
Just posting to bring this back up on the forum. Still not sure why I'd combine x and y
is my v(z) still constant with the electric field present?
The idea is certainly to just integrate them. However, quite often that's not directly possible. For this case, you can do so for z, as it does not involve any other function of t. To be very explicit, what we're really doing is trying to find three function x(t), y(t) and z(t). So we begin with z(t):
[tex]\begin{align*}<br /> m \frac{d^2 z(t)}{dt^2} &= q E_z \\<br /> v_z(t) = \frac{d z(t)}{dt} &= \frac{q E_z}{m} t + v_z(0) \\<br /> z(t) &= \frac{q E_z}{2 m} t^2 + v_z(0) t + z(0)<br /> \end{align*}[/tex]
So [tex]v_z[/tex] is actually a linear function of t.
Now we could try the same with x(t). However, you notice that when trying to integrate, you've got [tex]v_y = \dot{y}[/tex] on the right hand side, which is a function of t. So you can't do the integral unless you've already got [tex]v_y[/tex]. Thus you get around this by differentiating the first equation wrt t, so that you've got [tex]\frac{d^3 x}{dt^2}[/tex] on the left and [tex]\ddot{y}[/tex] on the right. Then you can substitute the 2nd equation in, and treat it as a 2nd order differential equation in [tex]\dot{x}[/tex].
Physics Question about an electron
Aslam O Alaikum.
I am a new member here an dthis is my first post.
I want to know that What is difference between Magnetic field and Electric field?
Because If we read their general definations use in general physics Defination of both is same??
So what's their main difference ?
Thanks
M.Ahsen tahir
ahsen_tahirpk@hotmail.com
  • · Replies 31 ·
