| Thread Closed |
Non-uniform line charge density with r not constant |
Share Thread | Thread Tools |
| Sep27-07, 09:26 PM | #1 |
We have a non uniform line charge density [tex]P_{l}[/tex] = [tex]\rho_{l}[/tex] cos[tex]\phi[/tex] It is a spiral line where 0 [tex]\leq[/tex] [tex]\phi[/tex] [tex]\leq[/tex] 4 [tex]\pi[/tex] It is on the x-y plane with z=0. r varies: r ( [tex]\phi[/tex] ) = [tex]\phi[/tex] * [tex]r_{0}[/tex] + a We need to find the Potential and Electric Field at the origin. 2. Relevant equations V = (KQ/r) E = (KQ)/ r[tex]^{2}[/tex] E = -[tex]\nabla[/tex]V 3. The attempt at a solution The east way would be to find the Potential and then to find the Electric Field by using the relationship between E and the gradient of V. I think this problem wouldn't be as tough if r was constant. |
| Sep27-07, 10:05 PM | #2 |
So are you going to use a line integral? I suggest cylindrical coordinates.
Also, I don't know what phi is, the polar angle or some constant? Oh, nevermind I see where r is bounded. You still need to show some work before you get any help. |
| Sep27-07, 10:11 PM | #3 |
I've tried it, and I have gotten to the point where I have an integral that determines the potential at this point. Here's how I got this far:
For a bunch of separate point charges, we have [tex]V = \sum {\frac {-1}{4 \pi \epsilon_{o} } \frac {q_i}{r_i} }[/tex] where I've replaced [tex]\rho_l[/tex] with [tex]\lambda[/tex] to make things easier for me. (Sometimes [tex]\rho[/tex] denotes the radial distance.) For a line, we replace [tex]q[/tex] with [tex]d \lambda[/tex] and integrate. To do this, we need to replace [tex]d \lambda[/tex] with something with [tex]d \phi[/tex] in it; I'll leave the details up to you. We replace [tex]r[/tex] with your formula for [tex]r[/tex]. |
| Sep27-07, 10:14 PM | #4 |
Can I fix your formulas too?
[tex] V = k \int_{\Omega} \frac{\rho(\mathbf{r'})}{||\mathbf{r} - \mathbf{r'}||} d\gamma'[/tex] Which would specifically be [tex] V = k \int_l \frac{\lambda(\mathbf{r'})}{||\mathbf{r} - \mathbf{r'}||} dl'[/tex] for a line charge. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Non-uniform line charge density with r not constant
| how can a conductor of uniform charge density exist | Classical Physics | 7 | ||
| induced charge density by non-uniform dipole density in dielectric?! | Classical Physics | 1 | ||
| Uniform Charge Density | Introductory Physics Homework | 2 | ||
| Uniform Density Charge Problem | Introductory Physics Homework | 3 | ||
| Gaussian surface, and uniform charge density | Introductory Physics Homework | 3 | ||
