Register to reply
Tension and Angles
by Heat
Tags: angles, tension
Share this thread:
Heat
#1
Sep29-07, 11:19 AM
P: 273
A frame hung against a wall is suspended by two wires attached to its upper corners.
If the two wires make the same angle with the vertical, what must this angle be if the tension in each wire is equal to 0.75 of the weight of the frame? (Neglect any friction between the wall and the picture frame.)
2. Relevant equations
F=ma
w=mg
3. The attempt at a solution
I think it looks something like this:
It says .75 weight of frame, so I did the following to convert to N.
w=.75(9.8) = 7.35N
That is 7.35 on each side, and this is the part that get's me "if the tension in each wire is equal to 0.75 of the weight of the frame?"
I am lost, here. but for angle I think it should be something like this arc cos (14.7/7.35)
well at least i tried :D
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
Doc Al
#2
Sep29-07, 11:44 AM
Mentor
Doc Al's Avatar
P: 41,489
You are not given the weight of the frame so don't assume any particular value. Instead, just call that weight W.
You are given the tension in the wires in terms of that weight. The tension equals 0.75*weight, so T = 0.75*W.
Now apply the condition for equilibrium, namely that vertical forces acting on the frame must add to zero. (What are the vertical components of the wire tension?)
Heat
#3
Sep30-07, 11:30 AM
P: 273
so the tension on each wire is .75w, where w is unknown.
"condition for equilibrium, namely that vertical forces acting on the frame must add to zero."
vertical must add up to w, for them to cancel out, right?
if so where do I go from there.
the angle would not be:::: arc cosine (w/.75w)?
Doc Al
#4
Sep30-07, 11:35 AM
Mentor
Doc Al's Avatar
P: 41,489
Tension and Angles
Almost! Realize that there are two wires pulling up on the frame.
Heat
#5
Sep30-07, 11:38 AM
P: 273
so that means they are sharing the weight, so it should be half of w. ?
Doc Al
#6
Sep30-07, 11:41 AM
Mentor
Doc Al's Avatar
P: 41,489
Quote Quote by Heat View Post
You can certainly think of it that way.
Heat
#7
Sep30-07, 12:00 PM
P: 273
so it would be arc cosine of .5w/.75w = arc cosine .66 = 48.19 ?
Doc Al
#8
Sep30-07, 12:03 PM
Mentor
Doc Al's Avatar
P: 41,489
Yep. Looks good.
Heat
#9
Sep30-07, 12:05 PM
P: 273
thank you :)
Register to reply
Related Discussions
Tension of strings at different angles: Introductory Physics Homework 7
Tension with Different Angles Introductory Physics Homework 10
Mountain climber - center of gravity, tension, angles... Introductory Physics Homework 1
Tension, vectors and angles, oh my Introductory Physics Homework 4
Refrence Angles & Positive/Negative Angles(Coterminals) HOW? Introductory Physics Homework 1
