Linear algebra - find all solutions with complex numbers
The discussion revolves around solving a quadratic equation involving complex numbers and proving a condition related to complex magnitudes. The subject area is linear algebra, specifically focusing on complex numbers and their properties.
  • Participants discuss using the quadratic formula to find roots but express confusion regarding the presence of a complex number in the square root. There are suggestions to reconsider the approach to solving the quadratic equation without relying solely on the quadratic formula. Additionally, questions arise about how to prove the condition involving the magnitudes of complex numbers.
The discussion is ongoing, with participants exploring different methods to approach the quadratic equation and questioning the assumptions behind their chosen methods. Some guidance has been offered regarding the need to understand how to handle square roots of imaginary numbers, but no consensus has been reached on a specific method or solution.
Participants note difficulties with the complex term in the quadratic equation and express uncertainty about the appropriate methods to use for both parts of the problem. There is an implication that certain methods may not be suitable for the given problems.
braindead101
(a)Find all t [tex]\epsilon C[/tex] such that [tex]t^{2}[/tex] + 3t + (3-i) = 0. Express your solution(s) in the form x+iy where x,y [tex]\epsilon R.[/tex]
(b) Prove that | 1+iz | = | 1-iz | if and only if z is real.
Okay so I tried to use the quadratic formula to find the roots to find the solutions, but I am stuck because I have a complex number within the square roots.
t = -b +/- sqrt(b^2 - 4ac) / 2a
t = -3 +/- sqrt[(-3)^2 - 4(1)(3-i)] / 2(1)
t = -3 +/- sqrt(-3 + 4i) / 2
what do i do?
also for question (b), where do I even start?
1. Well, you should know how to take square roots of imaginary numbers, if you're supposed to use that method. Since you do not, it seems, why not retry the question without using the quadratic formula which you probably weren't supposed to use anyway. For example, I hope you wouldn't use the quadratic formula on x^2 - 5x +6 to find the roots of 2 and 3.
2. Iz z=x+iy, you want to show y=0. Well, what does the condition |1-iz|=|1+iz| imply?
I have tried finding the roots like a normal quadratic, but the last term (3-i) is throwing me off.
is there anyway to solve this instead of finding the roots like a normal quadratic.. is there an actual format to do that.. i seem to be just guessing..
  • · Replies 22 ·
  • · Replies 30 ·
  • · Replies 27 ·
  • · Replies 18 ·
