Drawing Free-Body Diagrams: Rock Suspended by Two Strings
  • Thread starter Thread starter fiziksfun
    Diagram
The discussion focuses on drawing free-body diagrams for a rock suspended by two strings, where the right string is longer than the left. Participants clarify that in static equilibrium, the tension in the strings must balance the weight of the rock, leading to the conclusion that the left string experiences greater tension due to its more vertical orientation. The concept of vector addition is emphasized, with the resultant forces forming a closed polygon, specifically a triangle in this scenario. Understanding these principles is crucial for accurately representing forces in free-body diagrams.
  • Understanding of static equilibrium in physics
  • Knowledge of vector addition and force diagrams
  • Familiarity with tension forces in strings
  • Basic skills in drawing and interpreting free-body diagrams
  • Study the principles of static equilibrium in greater detail
  • Learn about vector addition techniques in physics
  • Explore examples of free-body diagrams involving multiple forces
  • Practice drawing free-body diagrams for various scenarios
Students studying physics, educators teaching mechanics, and anyone interested in mastering the concepts of forces and free-body diagrams.
fiziksfun
My teacher asked us to draw a free body diagram for the following scenario:
(A rock is suspended by two strings. The right string is supposed to be longer than the left one. Static)
(looks like this:)
http://i23.tinypic.com/28u7ccn.jpg
My free-body diagram looks like this:
http://i21.tinypic.com/ojmhc1.jpg
Is this right? I don't understand why the tension in the left string would be more. Help!
(P.S. how do I insert a picture?)
Tension arises from the weight of the object that is being held by the string, the more vertical the string the more that downwards weight contributes to the tension, alternatively let's imagine a ball in the middle of a 2d square, attatched by 4 strings at 90 degree angles, the string at the top of the square has the highest tension, as it is holding the ball in its suspended position and its force is upwards (the force from the ball is downwards) the lowest tension string is at the bottom since the balls force is in the same direction that the string would apply its tension, unless the ball was pulling upwards due to some elastic streaching by the top string.
The side strings should potentially have no tension unless both strings were attempting the deviate the ball from a perfectly vertical position (angle them) and then the strings tension would be attributed by the strings deviating the ball from a free fall
This is just my guess on the subject though, I've never done free body diagrams.
If the object is in static equilibrium, the vector sum of all of the forces on the object will equal zero. This can be interpreted by adding those vectors tail-to-tip, and finding that the last tip meets the first tail, ... resulting in a [closed] polygon. In your case, you should find that the vectors (constrained by their directions) added tail-to-tip forms a triangle.
  • · Replies 19 ·
