| Thread Closed |
Kinematic problem |
Share Thread | Thread Tools |
| Sep30-07, 10:49 PM | #1 |
Kinematic problem
An object is thrown up from the top of a building 50 m high. It rises to a maximum high of 20 m above the roof. A) when does it land on the ground B) At what velocity does it land ? C) When is it 20 m below the roof? 2. Relevant equations The 4 kinematics equations the ones I used where Vf = Vi+ at vf ² = vi ² + 2ax 3. The attempt at a solution Well I am completely lost now. I don't know if we can do this in one shot or two. I first found out how much time it takes for the ball to attein maximum height which gave me 2.02 seconds. After I calculate the time it takes to go from that high to the ground and in total I got 6.35 s but the textbook gave me 5.84 as for the velocity I had - 42 m/s but the text book says -37 m/s :S I kept alot of decimals so I don't think the mistake is there |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Sep30-07, 11:18 PM | #2 |
So for the first path you should get that
[tex] t_1 = \frac{\sqrt{2gy_{high}}}{g}[/tex] For the second path you should use the distance equation [tex] t_2 = \sqrt{\frac{2 y_{net}}{g}}[/tex] These two times will give you just about everything. Is this what you got? |
| Sep30-07, 11:26 PM | #3 |
Step 1 : Decide the reference point for measuring the displacements i.e. y = 0 point and the +ve direction for displacement. It could be the ground in which case the initial displacement will be +50m and final displacement 0. Alternatively it could be the top of the building with upwards displacement +ve. In that case initial displacement will be 0 and final displacement -50m. Let us assume the second alternative.
Remember : velocities and accelerations in the direction of +ve displacement are +ve and otherwise -ve. Step 2 : First determine u by using v^2 - u^2 = 2as. At the highest point v = 0. Displacement s = +20m and acceleration a = -g = 9.8 m/s2 (-ve because g is downwards). Step 3 : Use s = ut + 1/2 at^2 to determine time of hitting the ground. s = -50m and a = -g Step 4 : To determine the landing velocity use v^2 - u^2 = 2as. u as determined above, a = -g and s = -50m Step 5 : When is it 20 m below the roof : s = -20m. Which equation will you use? |
| Sep30-07, 11:29 PM | #4 |
Kinematic problem
Good advice by Vijay, the only thing that I would add is to not put in any numbers until the absolute last moment possible. Do everything algebraically.
| Sep30-07, 11:31 PM | #5 |
Hmmm am not so familiar with those symbols is it,
u = initial velocity Still looking at it for now |
| Sep30-07, 11:50 PM | #6 |
Well thank you very much , this was pretty helpful I was never using a reference point correctly before, just got the last answer with Vf=Vi +at
| Thread Closed |
| Thread Tools | |
Similar Threads for: Kinematic problem
| Kinematic Problem | Mechanical Engineering | 12 | ||
| kinematic problem | Introductory Physics Homework | 5 | ||
| 1-d kinematic problem | Introductory Physics Homework | 8 | ||
| kinematic problem | Introductory Physics Homework | 1 | ||
| Kinematic Problem | Introductory Physics Homework | 4 | ||
