Energy Transfer in a Water and Aluminum Pan System
  • Thread starter Thread starter rkjul
    Heat
The problem involves energy transfer in a system consisting of boiling water and an aluminum pan. It requires calculating the temperature of the water after pouring it into the pan and determining the energy transfer from a stove to the system after additional work is done on the water.
  • Participants discuss the application of the energy equations, particularly the use of heat capacity and mass in calculating energy transfer. There are questions about the correct values for heat capacity and mass used in the calculations. Some participants attempt to derive a weighted average for heat capacity and total mass.
There is an ongoing exploration of the calculations needed for part B, with participants sharing their attempts and questioning the values used in their equations. Some guidance is offered regarding the combination of heat capacities and masses, but no consensus has been reached on the correct approach or values.
Participants note potential confusion regarding the system's definition and the implications of the work done on the water. There is also mention of the need to clarify the values used in calculations, which may be contributing to incorrect results.
rkjul
100 grams of boiling water (temperature 100° C, heat capacity 4.2 J/gram/K) are poured into an aluminum pan whose mass is 375 grams and initial temperature 24° C (the heat capacity of aluminum is 0.9 J/gram/K).
(a) After a short time, what is the temperature of the water?
(b) Next you place the pan on a hot electric stove. While the stove is heating the pan, you use a beater to stir the water, doing 1400 J of work, and the temperature of the water and pan increases to 74.6° C. How much energy transfer due to a temperature difference was there from the stove into the system consisting of the water plus the pan?
deltaE=mC*deltaT
deltaE=Q+W
Ok I got part A with no trouble but I'm struggling with part B. I tried using the mC*delta T equation for the water and the aluminum pan...adding those values and setting it equal to Q+W. I used 8.6 for delta T (74.6-66) since I got 66 degrees for my answer in part A. I then subtracted W to find Q in the second equation but it's not the correct answer. I think what might be throwing me is that the system consists of the water and pan. Any suggestions?
You didn't say what value of C you used in the second calculation. But C' should be the weighted average of the mass of the water and the aluminium ( British spelling), and M' the sum of the masses.
C' = (C1*M1 + C2*M2)/(M1+M2)
M' = M1 + M2.
I think this will work, but I could be wrong.
M' = M1 + M2.
I calculated two values of mC*delta T, one for the water (100*4.2*8.6) and one for aluminum (375*0.9*8.6) and added those together and set that equal to Q+1400. I got Q=5115 (same answer as you) and it's incorrect.
how did u get a?
25K
