Sequences and Convergence or Divergence?
The discussion revolves around determining the convergence or divergence of a sequence defined by the nth term n[1 - cos(2/n)]. Participants explore various approaches to evaluate the limit of the sequence as n approaches infinity.
  • Participants discuss the application of L'Hôpital's theorem and question its suitability in the context of the problem. There are attempts to simplify the expression using series expansion for cosine and to analyze the limit behavior of the sequence.
Some participants have offered guidance on the application of L'Hôpital's theorem and series expansion, while others express uncertainty about the correctness of their approaches. Multiple interpretations of the problem are being explored, and there is no explicit consensus on the final outcome.
There is a mention of potential confusion regarding the application of L'Hôpital's theorem, as well as the timing of introducing Taylor series in relation to the problem at hand.
Illusionist
Determine whether the following sequence, whose nth term is given, converges or diverges. Find the limit of each convergent one.
n[1 - cos(2/n)]
I have made a solid attempt and obtained an answer but I am convinced I made a mistake and have missed something.
lim n[1 - cos(2/n)]
lim [ n - n[cos(2/n)] ]
lim(n) - lim (n[cos(2/n)])
lim(n) - lim ( [cos(2/n)] / (1/n) ) <--- Now using L'Hopital's Theorem:
lim(n) - lim ( [(-2/n^2)sin(2/n)] / (-1/n^2) )
lim(n) - lim 2sin(2/n)
lim(n) - 2sin(lim [2/n])
Infinity - 0 = Infinity, hence divergent!
Note: Each limit (lim) shown about is the limit as n approaches infinity, just didn't write it every time to make things a bit neater.
Now for some reason that seems to simple and incorrect to me. Confirmation or any sort of help would be much appreciated.
Sorry about the confusing working above, thanks guys.
You can't apply l'Hospital's theorem to:
[tex]\frac{\cos (\frac{2}{n})}{\frac{1}{n}}[/tex]
since it's not of a suitable form. (The numerator goes to 1.)
Of course but I'm a bit stumped as to what to do with this one. Any suggestions? I presume that means what I did before applying L'Hopital's was right. Thanks for the reply.
[tex]\frac{1-\cos (\frac{2}{n})}{\frac{1}{n}}[/tex] is in a good form to apply L'Hopital to, isn't it?
How about this:
if [itex]cos x = 1-\frac{x^2}{2!}+\frac{x^4}{4!}-\frac{x^6}{6!}+...[/itex] replace all the x's with 2/n and you'll get the series expansion for cos(2/n)
then simplify [itex]n(1-cos(\frac{2}{n}))[/itex] and then check what happens as n tends to infinity...
I did this just to make the 1 in the problem disappear
Very true. Well I gave that a try and this is how I went:
lim [(-2/n^2)sin(2/n)] / (-1/n^2)
lim 2sin(2/n)
2sin (lim [2/n])
2sin(0)
0, hence convergent.
Please tell me I'm right! Thank you so much for the replies guys.
That's what I would do. And that's the answer I would get.
rock.freak667 said:
How about this:
There's nothing wrong with your method, but if Illusionist is in a typical calculus course introducing infinite series, you are anticipating things a little. Generally, convergence of infinite series and problems of the sort posted appear a while before Taylor series are discussed. (Otherwise, yeah, Taylor series certainly are a "nice big hammer" for dealing with problems of this sort...)
  • · Replies 21 ·
