Uniform Acceleration/Projectile Motion
  • Thread starter Thread starter barnaby
    Motion Uniform
The problem involves a long jumper's performance, specifically analyzing his jump distance, time in the air, and the vertical drop of his center of gravity. The subject area includes concepts of uniform acceleration and projectile motion.
  • The original poster attempts to calculate the horizontal velocity and vertical velocity at take-off, expressing uncertainty about how to proceed without knowing the projection angle. Some participants suggest using kinematic equations to find the vertical velocity.
The discussion is ongoing, with participants providing guidance on how to approach the vertical velocity calculation. There is recognition of confusion regarding the center of gravity, and some clarification has been offered, but no consensus has been reached on the overall solution.
Participants are working within the constraints of the problem statement, which includes specific measurements and a focus on deriving velocities and angles without additional information about the projection angle itself.
barnaby
"A long jumper's jump measures 7.5m, and he is in the air for 0.8s. His centre of gravity falls 0.95m between his take off and landing."
a) Calculate his horizontal velocity at take-off.
b) Show that his vertical velocity is 2.7(3) m/s.
c) Hence calculate the angle at which he projects himself at take-off.
[tex]v_{ave} = \Delta x / \Delta t[/tex]
[tex]v_{horiz.} = v_{result.}cos \Theta[/tex]
[tex]v_{vert.} = v_{result.}sin \Theta[/tex]
There may be some more that have to come into use, too...
I calculated that his horizontal velocity at take-off is 9.38m/s, since he travels 7.5m horizontally in 0.8s.
I have spent about an hour trying to work out what to calculate, and how, in order to be able to calculate the vertical velocity at take-off.
I tried to calculate his instantaneous velocity at the point where his centre of gravity had reached its original point, but I couldn't since I don't know the angle at which he was projected...
It all goes downhill from here, really.
Any help would be greatly appreciated.
Thanks a lot.
d = v1*t + (1/2)at^2
apply this equation for the vertical direction. you have t, a and d. you can solve for v1.
Oh, of course... the centre of gravity thing threw me a bit. Thanks!
No prob. just use d = -0.95m
  • · Replies 18 ·
