Thread Closed
Specific heat of certain hard water(hardness measured with gpg)
Share Thread
Oct5-07, 08:30 AM   #1
ok so this is my first post and im not sure if what im looking for is even possiable or that im even posting in the right form.. anyways
im looking for a way to find the specific heat of a water sample depending on the hardness, i measure hardness with grains per gallon (gpg). and im realistic i realize that hardness even at a measured or set rate is different between water samples because of the variations of dissolved rock and minerals, so it will be an estimation at best.
idealy i want to be able to figure out specific heat of a hard water sample so i can compare it to the specific heat of filtered softened water, and then be able to compute boiling time ect...
i tried to google something about it but had no luck. maybe someone here can shed some light.
thanks,
ryan cheeseman
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
Thread Closed
Similar discussions for: Specific heat of certain hard water(hardness measured with gpg)
Thread Forum Replies
[SOLVED] Quantity of Heat/Specific Heat Water+Iron Introductory Physics Homework 3
specific heat of a piece of metal dropped in water Introductory Physics Homework 5
A very hard question about specific heat. Introductory Physics Homework 1
specific heat ratios of water, air, and related questions Introductory Physics Homework 1
Why does water have a high specific heat? Chemistry 1
