Acceleration,Time,Velocity with Friction Problem?
  • Thread starter Thread starter davidco
    Friction
The discussion revolves around a physics problem involving an otter sliding down a mud bank, focusing on concepts of acceleration, time, and velocity while considering the effects of friction. The problem includes parameters such as mass, length of the incline, coefficient of friction, and the angle of the incline.
  • Mixed
  • Participants explore the application of Newton's second law, questioning the correct equations for calculating acceleration, time, and velocity. There are discussions about the role of friction and the importance of the angle in resolving forces.
Participants are actively engaging with the problem, sharing equations and attempting to clarify their understanding of the forces involved. Some have provided guidance on drawing free-body diagrams and identifying forces, while others are checking their calculations and assumptions regarding the normal force and friction.
There is an ongoing discussion about the correct interpretation of forces, particularly how friction acts in relation to the motion of the otter down the incline. Participants are also considering the implications of their chosen coordinate system on the signs of their results.
davidco
Oscar the otter is having fun sliding down a mud bank.
Oscar has a mass m=13.2kg
The length of the mud bank is L=4m
The coefficient of kinetic friction between Oscar and the bank is MU=.365
The angle the mud bank makes W.R.T. the horizontal is theta=26.2 degrees
A) Calculate Oscar’s acceleration down hill? A=
B) Starting from rest at the top of the mud bank, how long will it take Oscar to slide the length of the hill and go for a swim? T=
C) Starting from rest from the top of the hill, what is Oscar’s velocity as he hits the water? V=
After work, Oscar decides to calculate what he could about the day’s fun. He found that taking the +x axis to lie along the bank and pointing down hill seemed to make solutions a little easier.
A)Not really sure about this equation EFx=mg sin theta
B)Delta x=1/2at^2 solve for t
C)V=at
A)Is my equation correct for acceleration and how do i equate my friction of MU into the correct equation?
B)To solve for time would the equation stated above be correct?
C)Would my velocity equation be correct for this problem?
Please help I need some direction and it starts with my equations because i really have no good examples of this problem. Thank you
Draw a freebody diagram... take the x-axis along the plane... y-axis perpendicular to the plane...
use the equations: [tex]\Sigma{F_x} = ma_x[/tex] and [tex]\Sigma{F_y} = ma_y[/tex].
here ay = 0, hence [tex]\Sigma{F_y} = 0[/tex]... because the otter can't travel into the plane...
Thank you but still alittle confused,
So I should just use the EFX=max equation only?
Will my EFx equal my friction .365 correct?
Im sort of confused would my equation look lke this:
(.365)/13.2kg=a
and what importance is my theta of 26.2 degrees?
(.365)/13.2kg=a
0.365 is not the friction, but the coefficient of friction... to get friction you need the normal force... then friction = 0.365*normal force.
it is important to draw the freebody diagram so that you see all the forces involved...
The theta is necessary to get the components of gravity along the plane (x-axis), and perpendicular to the plane (y-axis).
For [tex]\Sigma{F_x} = ma_x[/tex]... friction is not the only force. you also have the component of gravity along the plane.
Ok,
So my Normal force would be 13.2kg(9.8m/s^2)=129.36N correct?
Then I take my friction formula and do 0.365(129.36N)=47.21 correct?
davidco said:
Ok,
no, you need to take into account the angle... have a look at this page:
http://www.ac.wwu.edu/~vawter/PhysicsNet/Topics/Dynamics/InclinePlanePhys.html
it explains how to deal with inclined planes etc...
Thanx again Learn, the website was a lot of help.
What I was able to get from it was that the overal equation i need for acceleration is:
a=Fapp-un-mg(sin theta)/m
Is this the correct formula? If so what is my Fapp and un?
Yes, that's exactly the right formula. In this case there is no applied force.. Fapp = 0.
[tex]\mu*N[/tex] = 0.365*N
For N have a look at the website...
Have a look at:
"Incline Plane with Parallel Applied Force and Friction" in the website... this is exactly like your problem. only difference is in this case Fapp = 0... everything else is exactly the same as for your problem.
Ok I might just have it:
This is what i did
N=mgcos theta
N=(13.2)(9.8)cos(26.2)
N=116
Then I use
a=Fapp-uN-mg(sin theta)/m
a=0-(0.365)(116)-(13.2kg)(9.8m/s)(0.441)/13.2kg
a=?
Are my numbers mostly right?
Im concerned about the -(minus) signs because I am getting negative outcomes,should I turn the minus signs positive because of my positice numbers?
Oh... I made a mistake.
This situation is not exactly the same as the one I pointed out in the websiste because friction is in the opposite direction...
In this case the block is moving down the plane, but friction opposes motion so it is up the plane...
if we take down the plane as negative, and up the plane as positive:
[tex]a = \frac{\mu*N - mgsin(\theta)}{m}[/tex]
so a = [(0.365)116 - 13.2kg(9.8m/s)(0.4415)]/13.2
a = -1.12m/s^2
the minus sign just means the acceleration is down the plane (it just indicates direction)... if we took our initial convention to be down the plane as positive and up the plane as negative, it would come out as +1.12m/s^2...
Ok I gotcha thanks a whole lot, so for my part B I just use this equation
For part C i use V=at
Are they correct? If so what is my Delta x
Yup. that all looks right. you're delta x is the length of the mudbank which is 4m
  • · Replies 16 ·
