Thread Closed
Using Henderson-Hasselbach equation?
Share Thread Thread Tools
Oct5-07, 11:25 PM   #1
pH = pKa + log [base/acid] (H-H equation)
Using the H-H equation, calculate the theoretical volume of 0.2 M NaOH required to raise the pH of 0.1 M Tris HCl (pk = 8.1) to raise the pH to its pK value.
The way I see it is to get pH = pK so using H-H equation:
8.1 = 8.1 + log[0.2 M NaOH/0.1 M Tris HCl]
8.1-8.1 = log[0.2 M NaOH/0.1 M Tris HCl]
0 = log[0.2 M NaOH/0.1 M Tris HCl]
Then taking anti log,
1 = [0.2 M NaOH/0.1 M Tris HCl]
1 = 0.5
means
pH = 1, has base:acid ratio of 1/2
Thus if I have 0.1 mol/litre Tris HCL, I need half of 0.2 M NaOH.
But how do I convert these to volumes?
Please forgive me for asking this Q. I am really stuck. Am I on the right track? If so, how do I proceed to get the volumes. If not, what am I thinking that is wrong?
Please give up a detailed understanding of what I did wrong?
I would really appreciate it. Thanks.
Then I am suppose to draw a curve but how can I? with only one point at the theoretical volume of 0.2 M NaOH. I just don't understand. Please help me understand what they want from me.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Oct6-07, 01:21 AM   #2
I think I erred in my reasoning. I should be using the c1*v1 = c2*v2 formula
There is 50 mL of 0.1 M Tris HCl acid
So Let v1 = 50 mL = 0.050 L
c1 = 0.01 M Tris HCl
Then c2 = 0.2 M NaOH
v2 = ? mL
c1*v1 = c2*v2
(0.1 M Tris HCl)*(0.05 L) = (0.2 M NaOH) v2
Isolate v2:
v2 = c1*v1/c2
v2 = [(0.1 M Tris HCl)(0.05 L)] / 0.2 M NaOH
= 0.025 L
= 25 mL
Is this correct? Please let me know if I am wrong or on the wrong track. THANKS.
Oct6-07, 09:24 AM   #3
Is the stoichiometry between NaOH and tris HCl 1 : 1 ?
Oct6-07, 09:30 AM   #4
This is how I would solve the problem if the stoichiometry between NaOH and tris HCl is 1 to 1 . Incase not , you still apply the same method.
First NaOH reacts with Tris HCl . The reaction is quasi-quantitative and complete. Clearly NaOH must be the limiting reactant. Then after the reaction is over , there must remain Tris HCL + its conj base so that pH = pK_a
that is , the concentration of Tris-HCl remaining is :
[tex] M_{acid} = \frac{0.1V_{T-HCl} - 0.2V_{NaOH}}{V_{T-HCl} + V_{NaOH}} [/tex]
The concentration of the conj base is :
[tex] M_{base} = \frac{0.2V_{NaOH}}{V_{T-HCl} + V_{NaOH}}[/tex]
Since pH = pK_a and ofcourse assuming a buffer is formed,
Then according to HH equation :
[tex] Log_{10} \left( \frac{M_{base}}{M_{acid}} \right) = 0 [/tex]
[tex] \frac{0.2V_{NaOH}}{0.1V_{T-HCl} - 0.2V_{NaOH}} = 1 [/tex]
[tex] 0.1V_{T-HCl} - 0.2V_{NaOH} = 0.2V_{NaOH}} [/tex]
[tex] V_{NaOH} = \frac{V_{T-HCl}}{4} [/tex]
If the initial volume of tris HCl is known , the volume of NaOH can be calculated.
Oct6-07, 11:25 PM   #5
Thank you so much.
Oct6-07, 11:40 PM   #6
Need to prepare buffer with Henderson-Hasselbalch Equation?
Use the H-H equation to calculate the volume of 0.1 M acetic acid and 0.1 M Na acetate required to prepare 50 ml 0.1 M acetate buffer pH 4.0.
HH: pH = pk + log[base/acid]
Acetic acid is an acid but acetate is not a base. Acetate is a weak acid but I put it as a base bc how am I suppose to use HH to get a ratio?
Here is what I tried:
pH = pka + log[0.1 M acetate/0.1 M acetic acid]
4.0 - 4.76 = log[0.1 M Na acetate/0.1 M acetic acid]
0.76= log[0.1M Na acetate/0.1 M acetic acid]
5.75 = [0.1 M Na acetate/0.1 M acetic acid]
5.75 = [0.1 NaOH]/[0.1 acetic acid]
[acetic acid] = NaOH/5.74
Vol of acetic acid = (50 ml) [NaOH]/5.74
= 8.71 ml
Vol of acetate = 50 ml - 8.71
= 41.3 ml
However, these are wrong answers.
The correct answers should be:
42.6 ml 0.1 M acetic acid + 7.4 ml 0.1 M Na acetate to give pH 4.0.
Tell me what i did wrong and how to derive at the correction solutions above.
Thanks.
Oct7-07, 11:00 AM   #7
Sodium acetate is nothing but the conjugate base of acetic acid.
According to HH equation,
[tex] \frac{[NaOAC]}{[HOAC]} = 10^{pH - pK_a} [/tex]
At equilibrium ,
[tex] [NaOAC] = \frac{[NaOAC]_o V_{NaOAC}}{V_T} = \frac{(0.1)V_{NaOAC}}{V_T} [/tex]
[tex] [HOAC] = \frac{[HOAC]_o V_{HOAC}}{V_T} = \frac{(0.1)(V_{HOAC})}{V_T} [/tex]
[tex] \frac{[NaOAC]}{[HOAC]} = \frac{V_{NaOAC}}{V_{HOAC}} [/tex]
By simple substitution ,
[tex] \frac{V_{NaOAC}}{V_{HOAC}} = 10^{pH - pK_a} \ \ \ ... eq \ (1) [/tex]
We need to relate the two volumes inorder to solve a system of 2 equations , 2 unknowns. Notice that,
[tex] V_T = V_{HOAC} + V_{NaOAC} \ \ \ ... eq \ (2)[/tex]
V_T , pk_a , and pH are ofcourse given.
Solve to get :
[tex] V_{NaOAC} = \frac{(V_T)(10^{pH - pK_a})}{ 1 + 10^{pH - pK_a} } [/tex]
[tex] V_{HOAC} = \frac{V_T}{1 + 10^{pH - pK_a} } [/tex]
Plug in numerical values to get the required values of both volumes.
Oct7-07, 11:16 AM   #8
You have an initial conc of HOAC and NaOAC ( both 0.1 M ) but both volumes are unknown. The HH equation says that pH = pK_a + log ( [base] / [acid] ) where [base] and [acid] are the concentrations are equlibrium. So what did you do ?
You plugged in 0.1 for each , which is wrong. That is because you must take into account the dilution factor. Remember that you are to add an unknown volume of 0.1 M of acid and an unknown volume of 0.1 M base. Hence , the amount of acid and base are , respectively :
[tex] n_{HOAC} = 0.1 V_{HOAC} [/tex]
[tex] n_{NaOAC} = 0.1 V_{NaOAC} [/tex]
Since a buffer is to be formed, then the amount of acid and base is approximately constant. Their concentrations at equilibrium are then ,
[tex] C_{HOAC} = \frac{n_{HOAC}}{V_T} = \frac{0.1 V_{HOAC}}{V_{HOAC} + V_{NaOAC}} [/tex]
[tex] C_{NaOAC} = \frac{n_{NaOAC}}{V_T} = \frac{0.1 V_{NaOAC}}{V_{HOAC} + V_{NaOAC}} [/tex]
Once you've realized that , the rest becomes pure basic algebra.
You start by plugging the expressions of the concentrations in the HH equation and solve to find each V.
Oct7-07, 11:44 PM   #9
Thanks so much. I've been ill and still am so I can't get my head to think straight. I really appreciate your help Hunt_.
Oct7-07, 11:49 PM   #10
Preparing a sample buffers using weak acid/strong base?
You will be provided with 0,5 M acetic acid as a source of acetic acid and 0.2 M NaOH with which to prepare the same 0.1 M buffers.
a) Calculate the number of moles of acetic acid required to prepare 50 ml of a 0.1 M buffer. Then calculate the volume of 0.5 M acetic acid needed to prepare 50 ml of 0.1 M buffer.
b) Use the Henderson-Hasselbalch equation to calculate the number of moles of NaOH required to bring the pH up to 4.0 and 5.0 Then calculate the volume of 0.2 M NaOH that contains the number of moles.
Answers:
10 ml (0.5 M acetic acid) + 3.7 ml (0.2 M NaOH to give pH 4.0)
10 ml (0.5 M acetic acid + 15.9 ml (0.2 M NaOH to give pH 5.0)
I got 10 ml of 0.5 acetic acid by calculating:
c1 = 0.1 M, v1 = 50 ml = 0.050 L
c2 = 0.5 M, v2 = ?
c1*v1 = c1*v2
v2 = cv*v1/c2
= 0.1 M * 0.050 L/0.50 M.
= 0.01 L
= 10 mL
But do I using H-H eq, to get the following:
Additional Details
6 hours ago
I tried:
pH = pka + log [Mbasic/Macid]
Mbasic = 0.2 NaOH
Vacetic acid + VNaOH
4.0 = 4.76 + log[0.2 M NaOH/0.5 M acetic acid]
4.0 - 4.76 = log[0.2 M NaOH/0.5 M acetic acid]
0.76 = log[0.2 M NaOH/0.5 M acetic acid]
10^5.75 = log[0.2 NaOH/0.5 M acetic aid]
5.75 = [0.2 M NaOH/0.5 M acetic acid]
Am I on the right track? How do I proceed to get to the answer of 3.7 ml 0.2 M NaOH to give pH 4.0
Oct8-07, 12:31 AM   #11
Answers:
c2 = 0.5 M, v2 = ?
c1*v1 = c1*v2
v2 = cv*v1/c2
= 0.01 L
= 10 mL
b)
Mbasic = [0.2 NaOH]/[Vacetic acid + VNaOH]
Macid = [0.5 V acetic acid - 0.2 VNaOH]/[Vacetic acid - VNaOH]
Mbasic/Macid = [0.2 V NaOH]/[V acetic acid - V NaOH]
4.0 = 4.76 + log[Mbasic/Macid]
4.0 - 4.76 = log[0.2 V NaOH/0.5 V acetic acid - 0.2 V NaOH]
0.76 = log[0.2 V NaOH/(0.5 V acetic acid - 0.2 V NaOH)]
10^5.75 = log[0.2 V NaOH/(0.5 V acetic acid - 0.2 V NaOH)]
5.75 (0.5 Vacetic acid - 1.15 VNaOH) = 0.2 V NaOH
2.88 V acetic acid - 1.15 V NaOH = 0.2 V NaOH
0.2 V NaOH + 1.15 V NaOH = 2.88 V acetic acid
1.35 V NaOH = 2.88 V acetic acid
V NaOH = 2.88 V acetic acid/1.35 V
= 2.13 mL
HOwever, this is not the right answer. The correct answer should be VNaOH= 3.7 ml 0.2 M NaOH to give pH 4.0.
and V NaOH = 15.9 ml (0.2 M NaOH to give pH 5.0)
Do you see where I erred?
I am apologetic if I seem slow or unable to think. I know you don't know me but I am very ill/bedridden. School is all I have. I really need your help, not asking for sympathy but hope that you don't lose patience with me. I really don't want to trouble you. I appreciate the help you've given me so far. Thank you for your patience.
Oct10-07, 07:01 AM   #12
The reaction occuring is :
[tex] NaOH + HOAC \rightarrow H_2 O + NaOAC [/tex]
For part 1 :
If n_o is the initial amount of the acid , and x is the amount of NaOH. Then after the rxn is complete, n_o - x is the remaining amount of the acid and x is the amoun formed of its conjugate base.
Notice the total amount of moles between the acid and its conj base is :
Initiall : n_o + 0 = n_o
Finally : n_o + x - x = n_o
The number of particles is conserved between the two. ( Thay is why C1V1 = C2V2 works well here . )
Accoriding to the given , we have a 0.1 M buffer. At eq , the conc of the acid + it conj base :
[tex] [HOAC] + [NaOAC] = 0.1 M [/tex]
Multiplying the total volume , V = 50 ml.
[tex] n_{HOAC} + n_{NaOAC} = 5 mmol [/tex]
We proved above that :
[tex] n_{HOAC} + n_{NaOAC} = n_o [/tex]
So , n_o = 5 mmol ( initial amount of acid ) . It follows that the volume of acetic acid needed is 5 mmol / 0.5 M = 10 ml.
For part 2 :
From HH equation ,
[tex] \frac{n_{NaOAC}}{n_{HOAC}} = 10^{pH - pK_a} [/tex]
By substitution ,
[tex] \frac{n_{NaOAC}}{n_o - n_{NaOAC}} = 10^{pH - pK_a} [/tex]
Rearrange to get :
[tex] n_{NaOAC} = n_o \frac{10^{pH - pK_a}}{1 +10^{pH - pK_a}} [/tex]
since n_{NaOAC} formed = n_{NaOH} reacted then :
[tex] n_{NaOH} = n_o \frac{10^{pH - pK_a}}{1 +10^{pH - pK_a}} [/tex]
To find its volume , use
n = CV. It follows :
[tex] V_{NaOH} = \frac{n_o}{0.2} \ \ \frac{10^{pH - pK_a}}{1 +10^{pH - pK_a}} [/tex]
Oct10-07, 07:03 AM   #13
I will look later and see where you made your mistake . Sorry but there's No time now...
Oct11-07, 05:10 PM   #14
Your method is correct but you have few calculation errors.
b)
Mbasic = [0.2 V NaOH]/[Vacetic acid + VNaOH]
Macid = [0.5 V acetic acid - 0.2 VNaOH]/[Vacetic acid + VNaOH]
Mbasic/Macid = [0.2 V NaOH]/[V acetic acid - 0.2 V NaOH]
correct
4 - 4.76 = - 0.76 NOT 0.76
Where did you get 5.75 from ? You take the anti-log of -0.76 :
10^(-0.76} = [0.2 V NaOH/(0.5 V acetic acid - 0.2 V NaOH)]
= 2.13 mL
the correct expression should be : V (NaOH) = 0.37 V (HOAC)
It follows V (NaOH) = 3.7 ml
P.S.
Notice that Vacetic acid + VNaOH < 50 ml ( total volume ) in both cases. this is to show you that some water has been added to the solution to reach 50 ml although this is not mentioned in the given.
Therefore , when writing down the Molarity of , say the conjugated base :
You made a mistake by not including the volume of water added. Instead you can just write V_T ( or Vacetic acid + VNaOH + V water ) or 50 ml ( since it is known ). It is not a fatal mistake because once you take the ratio [base]/[acid] , the denominator is the same and so would cancel.
Also notice that instead of doing this numerical tedious work , you can derive a general equation and then finally plug in the given constants. This way , you get to solve the 2 similar cases of part b much faster , you only need to change the pH value and V(NaOH) is determined instantly with less probability of calculation error.
Aug1-10, 05:46 AM   #15
heya. hi :)) i'm new here?
can i use some help too? i'm having a hard time
to this :
-using Henderson-Hasselbalch equation, calculate
the volume of 0.2 M aceic acid and 0.2 M sodium acetate,
needed to prepare 50 ml of 0.1 M acetate buffer solution (pH=4.5).
pKa of acetic acid is 4.74. please i need a help and a solution for this.
thanks so much :))
Aug1-10, 09:11 AM   #16
Mentor
Please start a new thread to ask your question.
Thread Closed
Thread Tools
Similar Threads for: Using Henderson-Hasselbach equation?
Thread Forum Replies
Deriving the continuity equation from the Dirac equation (Relativistic Quantum) Advanced Physics Homework 3
Why is Euler equation similar to the gradient of Hamilton-Jacobi equation? General Physics 1
Henderson-Hasselbach Chemistry 1
Hendersen Hasselbach Chemistry 1
