Find Angle to Pull Toaster Cord for Min. Tension
  • Thread starter Thread starter pf21avs
The discussion focuses on determining the optimal angle to pull a toaster cord to minimize tension while overcoming static friction. The toaster has a mass of 1.13 kg and a static friction coefficient of 0.395. The solution involves analyzing the forces acting on the toaster using a free body diagram (FBD) and applying the condition for minimum tension by differentiating the tension equation with respect to the angle theta. The key insight is that the tension force must be directed at an angle that allows movement without increasing the required force excessively.
  • Understanding of static friction and its coefficient
  • Knowledge of free body diagrams (FBD)
  • Basic principles of tension and force components
  • Ability to perform differentiation in calculus
  • Learn about the physics of static and kinetic friction
  • Study how to construct and analyze free body diagrams
  • Explore the application of calculus in optimizing force equations
  • Investigate the relationship between angle and tension in physics problems
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of force analysis in real-world applications.
pf21avs
A 1.13 kg toaster is not plugged in. The coefficient of static friction between the toaster and a horizontal countertop is 0.395. To make the toaster start moving, you carelessly pull on its electric cord. For the cord tension to be as small as possible, you should pull at what angle above the horizontal?
FBD maybe a sum of all forces problem
in my fbd i have come to the point where in the x direction i have Ff=Ftcos(theta) and in the y direction i have fn=fg-ftsin(theta), well i know i can substitute the fn equation for Ff=(mu)fn however once I'm done simplifying i get ftcos(theta)=(mu)Fg-(mu)Ftsin(theta). two unknowns and one equation, i went to the physics tutors office and he told me that fn disappears but when i asked why he just said its in the question and left me to myself, i feel as though i have expended all resources and was wondering if someone could help with this question pleasE?
note: i apologize for the lack of grammerical correctness
A free body diagram is a good start. However, I believe this problem is solvable without all those equations--think about it for a moment. When is the tension force the smallest and the toaster still moving?
Consider what happens when the tension force is at an angle of 90 degrees to the horizontal. The component of the tension force that makes it move would be Ft*cos (90 degrees). Since cos (90 degrees) = 0, then no part of the tension force is making the object move, so the object is not going to move. Then consider what would happen if the angle of the tension force to the horizontal is 90...
Good luck. ;)
You have written the equation correctly. Next apply the condition for minimum T with respect to theta (differential of T with respect to theta = 0). Differentiate the equation you have already written wrt theta and in that put dT/dtheta = 0. Solve for theta. [Try. If still in doubt post again with the work done].
10K
