Electric field between two charged rods
The problem involves calculating the electric field strengths at specific distances from two uniformly charged glass rods placed parallel to each other. The context is rooted in electrostatics, specifically the behavior of electric fields generated by charged objects.
  • Exploratory, Assumption checking
  • Participants discuss the calculation of electric fields at various distances and the effects of the rods being charged. There is an attempt to compute the electric field strength using a specific formula, with some questioning the direction of the fields produced by each rod.
The discussion is ongoing, with participants clarifying the directionality of the electric fields from each rod and recognizing the need to account for their opposing signs. Some guidance has been offered regarding the interpretation of the problem and the importance of course material.
Participants reference a specific textbook and section related to the problem, indicating a structured approach to the homework assignment. There is an acknowledgment of potential misunderstandings in the calculations presented.
aliaze1
Two 10-cm-long thin glass rods uniformly charged to are placed side by side, 4.0 cm apart. What are the electric field strengths at distances 1.0 cm, 2.0 cm, and 3.0 cm to the right of the rod on the left, along the line connecting the midpoints of the two rods?
[1/(4??0)] * {|Q| / [r* (r2+(0.5L)2)0.5]}
the power "0.5" is the square root; √
Calculating the charge @ 2cm seemed the easiest, so here is what I did:
L=0.1m
r=0.02m
Q=1*10-8
1/(4??0) = 9*109
plugging these numbers in, I get 83562.90218, and since there are two rods, and this is equidistant from both, I added Erod#1 + Erod#2, which is the same as doubling the value, giving 167125.8044; incorrect
The two fields due to each rod are in opposite directions.
so their signs are opposite...thanks!
This question is from section 27.3, Question 9 from the book "Physics for scientists and engineers second edition. A strategic approach" by Randall D. Knight, which is probably the most standard undergraduate physics text available and extremely good, and it even has answers for all the odd numbered questions.
I suggest reading your course material.
  • · Replies 16 ·
  • · Replies 35 ·
