Solving Particles Colliding Homework: Mass of Struck Particle
  • Thread starter Thread starter kateman
    Particles
The problem involves a neutron colliding elastically with a stationary particle of unknown mass. The neutron rebounds with a specified velocity, and participants are tasked with determining the mass of the struck particle using conservation of momentum and kinetic energy principles.
  • Mixed
  • Participants discuss the application of conservation laws, attempting to set up equations for momentum and kinetic energy. Some express confusion over the signs of velocities and the implications of directionality in their equations.
There is ongoing exploration of the equations and their rearrangements. Some participants have offered corrections regarding the treatment of kinetic energy as a scalar and the importance of direction in momentum calculations. Others are seeking further guidance on how to proceed with their attempts.
Participants are working under the constraints of homework guidelines, which may limit the amount of direct assistance they can receive. There is also an acknowledgment of small errors affecting their calculations.
kateman
A neutron (m= 1.6 x10-27) moving with speed Vo strikes a stationary particle of unknown mass and rebounds elastically straight back along its path with a velocity of .7Vo. What is the mass of the struck particle?
P initial = P final
Ke initial = Ke final
alright i tried saying that the velocity imparted on the stationary particle was .3Vo but that gave me an answer of a mass of a neutron when the actual answer is 9.46 x 10-27.
i know: v1i = Vo
v2i = 0
v1f = .7Vo
but i am unsure as how to continue on from here. Please help.
Let mass of the stationary particle be m and its velocity after collision be V. Write down the equations for conservation of momentum and kinetic energy (keep in mind the +/- sign of the velocities). Solve these to obtain m. [If you are able to write down the equations but do not know how to solve them to get m, post again writing down upto the step you are able to reach]
yeah i understand what your saying:
1/2m1Vo^s = 1/2m1v1f^s+ 1/2m2 .7Vo^s
m1Vo = m1v1f + m2 .7Vo
what i have done is rearrange it for one value and then substitute it into the other equation but this still gives me the wrong answer. any ideas?
You should recall that momentum is a vector quantity and hence, direction is important.
1/2m1Vo^s = 1/2m1v1f^s - 1/2m2 .7Vo^s
ahhh well a negative in place of a positive might help :P
thanks hootenanny!
Careful though, I'm sure 1/2m2(0.7v02) should be 1/2m1(0.7v02). Assuming that m1 is your known mass
argh its these small errors that really throw me off
thanks again :)
thanks again :)
No problem :smile:
alright so i used
m1Vo^2 = -m1 .7Vo^2 + m2 V2f
v2f = m1Vo^2 + m1 .7Vo^2/m2
then i subs the v2f into the kinetic formula equation and ended up with this:
m1Vo^2 + m1 .7Vo^2/m2 = (m1Vo^2 + m1 .7Vo^2/m2)^2
0 = m1Vo^2 + m1 .7Vo^2/m2
alright, have i gone wrong somewhere and if so, where?
kateman said:
alright so i used
I'm not sure what you've done there, I think you may have got your equations mixed up. Kinetic energy is a scalar quantity; i.e. direction doesn't matter. And make sure you square the whole velocity. I'll start you off;
Momentum
[tex]m_1v_0 = m_1(-0.7\times v_0) + m_2v_2[/tex]
Kinetic Energy
[tex]m_1v_0^2 =m_1(0.7\times v_0)^2 + m_2v_2^2[/tex]
hmm i see the directions with ke did stuff me up
if the .7Vo velocity is negative, could you not just say that m1.7Vo as a whole is negative, and then rearrange as such?
i try to rearrange it but keep stuffing it up.
what should i do, rearrange on for v2f and then substitute it in the other? if so i need some more guidance
  • · Replies 54 ·
12K
  • · Replies 17 ·
