Solve Trig Substitution Integral: \int_{}^{} {\frac{x}{{\sqrt {3 - x^4 } }}dx}
The discussion revolves around evaluating the integral \(\int \frac{x}{\sqrt{3 - x^4}} \, dx\), which involves techniques of trigonometric substitution and algebraic manipulation. Participants are exploring the steps necessary to simplify and solve the integral, particularly focusing on the transformation of variables and the application of standard integral forms.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to apply trigonometric substitution and seeks clarification on a specific transformation involving the integral. Other participants discuss the algebraic manipulation of the denominator and question the steps taken to arrive at a standard integral form.
Participants are actively engaging with each other's reasoning, with some providing clarifications on algebraic steps. There is a productive exchange of ideas, although no consensus has been reached on the overall approach to the integral.
Participants are working within the constraints of class notes and expected to derive certain transformations independently. There is an emphasis on understanding the reasoning behind algebraic manipulations and substitutions.
tony873004
[SOLVED] trig substitution
This is from the class notes. Evaluate the integral:
[tex] \int_{}^{} {\frac{x}{{\sqrt {3 - x^4 } }}dx} [/tex]
[tex] \begin{array}{l}<br /> u = x^2 ,\,\,du = 2x\,dx\,\, \Leftrightarrow \,\,dx = \frac{{du}}{{2x}} \\ <br /> \\ <br /> \int_{}^{} {\frac{{x^1 }}{{\sqrt {3 - x^4 } }}dx} = \int_{}^{} {\frac{x}{{2x\sqrt {3 - u^2 } }}du} = \int_{}^{} {\frac{1}{{2\sqrt {3 - u^2 } }}du } \\ <br /> \end{array}[/tex]
The next step I would want to do using trig substitution is
[tex] \begin{array}{l}<br /> a = \sqrt 3 ,\,x = a\sin \theta = \sqrt 3 \sin \theta \\ <br /> \\ <br /> \frac{1}{2}\int_{}^{} {\frac{1}{{\sqrt {\sqrt 3 ^2 - \sqrt 3 \sin \theta } }}du} = \frac{1}{2}\int_{}^{} {\frac{1}{{\sqrt {3 - \sqrt 3 \sin \theta } }}du} \\ <br /> \end{array}[/tex]
But the next step in the example is:
[tex] \int_{}^{} {\frac{1}{{2\sqrt {3 - u^2 } }}du = } \frac{1}{2}\sin ^{ - 1} \frac{u}{{\sqrt 3 }} + C[/tex]
How did he get this? Thanks!
[tex]\int\frac{du}{2\sqrt{3-u^2}}=\frac{1}{2}\int\frac{du}{\sqrt{3}\sqrt{1-(u/ \sqrt{3})^2}}[/tex] then let y=u/sqrt(3) hence dy=du/sqrt(3), so we have [tex]\frac{1}{2}\int\frac{dy\sqrt{3}}{\sqrt{3}\sqrt{1-y^2}}=\frac{1}{2}\int\frac{dy}{\sqrt{1-y^2}}[/tex] which is a standard integral.
Thanks for the reply. But I don't see how you did this:
I know you're right, because I picked a random value for u and plugged both formulas into my calculator. But I just don't know how you got from one to the other.
Ok, well let's just consider the denominator: [itex]2\sqrt{3-u^2}[/itex]. This can be rewritten as [tex]2\sqrt{(\sqrt{3})^2-u^2}=2\sqrt{(\sqrt{3})^2[1-(u/\sqrt{3})^2]}[/tex] by factoring out \sqrt{3}^2. We can then take this outside the square-root sign to give [tex]2\sqrt{3}\sqrt{1-(u/\sqrt{3})^2}[/tex] as required.
I was about to write back and ask how you did that factoring, but now that I've stared at it for a few minutes, I see what you did.
They expected me to come up with that on my own??
Thanks, Christo :)
Thanks, Christo :)
You're welcome!
  • · Replies 22 ·
  • · Replies 105 ·
13K
