Lagrangian for a charged particle in a magnetic field
The discussion revolves around the derivation and interpretation of the Lagrangian for a charged particle in a magnetic field, specifically focusing on the term corresponding to the magnetic potential, -q\vec{v}\cdot\vec{A}. Participants explore the mathematical steps involved in arriving at this expression and the implications for the equations of motion.
  • One participant questions the derivation of the term -q\vec{v}\cdot\vec{A} in the Lagrangian and seeks clarification on the transition between different forms of the equations.
  • Another participant references a book, "The Classical Theory of Fields" by Landau and Lifschitz, as a source for explanations related to the topic.
  • A participant presents a detailed equation involving the forces acting on the particle, including terms for the electric potential and magnetic vector potential, and discusses the implications of these terms.
  • One participant reflects on their misunderstanding regarding the treatment of the magnetic vector potential and acknowledges the need for a total derivative rather than a partial derivative in their calculations.
Participants express differing levels of understanding regarding the derivation process, with some referencing external sources for clarification. There is no consensus on the specific reasoning behind certain mathematical steps, indicating that multiple interpretations or approaches may exist.
Participants note limitations in their understanding of the material, particularly regarding the transition between different forms of the equations and the treatment of derivatives. There is also mention of external references that may not be accessible to all participants.
mmcf
Hey I have a question that was almost completely answered in this thread:
https://www.physicsforums.com/showthread.php?t=116098
Specifically someone interpreted his question to be how exactly do you get that
the term in the Lagrangian corresponding to the magnetic potential is
[tex]-q\vec{v}\cdot\vec{A}[/tex]
da_willem said:
The only proofs I have seen rely on the Lagrangian principle. E.g.
The Lagrangian
[tex]L=T-V=\frac{1}{2}mu^2 + q\vec{u} \cdot \vec{A}[/tex]
Subsituted in the Euler Lagrange equations
[tex]\frac{d}{dt}\frac{\partial L}{\partial \dot{x}}=\frac{\partial L}{\partial x}[/tex]
Using generalised coordinates x, y, z with generalized velocities [tex]\dot{x}, \dot{y}, \dot{z}[/tex] and [tex]u^2=\dot{x}^2+\dot{y}^2+\dot{z}^2[/tex]
yields
[tex]\frac{d}{dt}(m\dot{x}+qA_x)=q\frac{\partial}{\partial x}(\dot{x}A_x+\dot{y}A_y+\dot{z}A_z)[/tex]
[tex]m \ddot{x}+q \frac{\partial A_x}{\partial t} =q(\dot{x}\frac{\partial A_x}{\partial x}+\dot{y}\frac{\partial A_y}{\partial x}+\dot{z}\frac{\partial A_z}{\partial x})[/tex]
or after rearranging
[tex]m \ddot{x}=-q(\frac{\partial \phi}{\partial x}+\frac{\partial A_x}{\partial t})+q[\dot{y}(\frac{\partial A_y}{\partial x}-\frac{\partial A_x}{\partial y})+\dot{z}(\frac{\partial A_z}{\partial x}-\frac{\partial A_x}{\partial z})]=qE_x+q(\dot{y}B_z-\dot{z}B_y)[/tex]
Which is exactly the x-component of the usual Lorentz force. So the potential term [tex]V=-q\vec{u} \cdot \vec{A}[/tex] can be motivated by the fact that it yields the right equation of motion.
Sadly, I had already worked up to the second to last line prior to his post, and I'm not clear
on what happened at that point. I would assume he added in [tex]\partial \phi/\partial x[/tex] because the electric potential is zero and that expression will look more like the typical [tex]E_x[/tex] that you see. The part that loses me though is how did he turn the term
[tex]\dot{x}\frac{\partial A_x}{\partial x}+\dot{y}\frac{\partial A_y}{\partial x}+\dot{z}\frac{\partial A_z}{\partial x}[/tex] into [tex]\dot{y}(\frac{\partial A_y}{\partial x}-\frac{\partial A_x}{\partial y})+\dot{z}(\frac{\partial A_z}{\partial x}-\frac{\partial A_x}{\partial z})[/tex]
Just from the looks of things it might be that:
[tex]\dot{x}\frac{\partial A_x}{\partial x} + \dot{y}\frac{\partial A_x}{\partial y} + \dot{z}\frac{\partial A_x}{\partial z} = 0[/tex]
I don't really see why that should be true, so is there another way he could have done that, or what is the reasoning behind that equation? Also, sorry in advance. I did take a look at Jackson but he jumps into some relativistic stuff that I'm not ready for right now and we don't have a copy of Franklin in our library.
It's explained in the book: "The Classical Theory of Fields" by Landau and Lifschitz.
[tex] m\frac{d{\vec v}}{dt}=<br /> q[-\nabla\phi-\partial_t{\vec A}+{\vec v}\times(\nabla\times{\vec A})] <br /> = q[-\nabla\phi-\partial_t{\vec A}-({\vec v}\dot\nabla){\vec A}<br /> +\nabla({\vec v}\cdot{\vec A})]<br /> =\nabla[-q\phi+q{\vec v}\cdot{\vec A}]-q\frac{d{\vec A}}{dt}.[/tex]
Alright thanks. It looks like my problem happened here:
when I assumed that you could take that derivative of [tex]A_x[/tex] with respect to time partially. If I had taken a total derivative I'd have seen instead:
[tex]m\ddot{x}+q\frac{\partial A_x}{\partial t} + q(\dot{x}\partial_x A_x + \dot{y}\partial_y A_x + \dot{z} \partial_z A_x) =q(\dot{x}\partial_x A_x +\dot{y}\partial_x A_y+\dot{z}\partial_z A_z)[/tex]
and that gives me what I was hoping for:
[tex]m \ddot{x}=-q\frac{\partial A_x}{\partial t}+q[\dot{y}(\frac{\partial A_y}{\partial x}-\frac{\partial A_x}{\partial y})+\dot{z}(\frac{\partial A_z}{\partial x}-\frac{\partial A_x}{\partial z})]=qE_x+q(\dot{y}B_z-\dot{z}B_y)[/tex]
