Does adding a dielectric to a capacitor increase the electric field?
The discussion revolves around the effects of inserting a dielectric into a capacitor with a constant potential difference. Participants explore how the dielectric influences the electric field and charge distribution within the capacitor.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants examine the relationship between charge, electric field, and potential difference when a dielectric is introduced. Questions arise regarding why an increase in charge does not lead to an increase in the electric field, despite the dielectric's presence. Some seek a conceptual understanding rather than a mathematical explanation.
The discussion is active, with participants offering insights and questioning assumptions about the behavior of electric fields in the presence of dielectrics. There is a mix of mathematical reasoning and conceptual exploration, with some participants affirming each other's points.
Participants are navigating the implications of dielectric constants and charge distributions, while also considering the nature of electric fields generated by different charge configurations. The conversation reflects a blend of theoretical inquiry and practical understanding of capacitor behavior.
indigojoker
there is a capacitor with a constant potential difference of V in air. When a dielectric is completely inserted between the plates of the capacitor completely filling it, additional charge flows onto the positive plate.
The additional charge should be Q=kCV-CV right?
Would the induced charge on either faces of the dielectric be Q=kCV?
Since the dielectric doesn't change the electric field (V=ED), why doesn't the increase in charge on the plates increase the field?
Yes, kCV is correct. extra charge is kCV - CV.
V = Ed
V is the same. d is the same. So E must be the same.
V = Ed
since there is an increase in charge on the plates, why doesn't this give rise to an increase in the E field since the increase in the chrage on the plates should serve to increase the field between the plates? I know V is the same and so E must be the same, I'm looking more for a conceptual idea.
also, there is kCV charge on the top on the dielectric right? does that mean that there is a -kCV charge on the bottom of the dielectric?
Well, the field is [tex]\frac{\sigma}{\epsilon}[/tex] which is [tex]\frac{Q}{A\epsilon}[/tex]
so how does this change when the dielectric is inserted...
yes.
charge increases when the dielectric is inserted so shouldn't the field increse too?
to: [tex]\frac{kCV}{A\epsilon}[/tex]
k is the dielectric constant. so [tex]\epsilon = k\epsilon_0[/tex]
plug this in and the k's cancel in the numerator and denominator...
so you're left with
[tex]\frac{CV}{A\epsilon_0}[/tex], which is just like without the dielectric.
okay, so i want to understand this in a non mathematical way.
in the same situation as above, we insert a dielectric and then we get an increase in charge on the plates. the reason why we don't get an increase in the E-field is because the dielectric creates an opposing field that makes it so the E-field does not change. is the right?
Yes, that is correct.
but since the dielectric has the same amount of charge as the metal plates, wouldn't the two E-fields cancel out?
No, just because the charge is the same doesn't mean the field is the same.
what is the field in the dielectric?
would it be:
[tex]E=\frac{kQ}{A\epsilon_o}-\frac{Q}{A\epsilon_o}[/tex]
indigojoker said:
would it be:
Yeah... I would write it as: [tex]E=\frac{Q}{A\epsilon_o}-\frac{kQ}{A\epsilon_o}[/tex]
so when you add the field due to just the charge... you get the net field...
  • · Replies 17 ·
  • · Replies 20 ·
