Impulse and average force of ball
The problem involves a ball of mass m striking a vertical wall at an angle, with the collision being elastic and friction negligible. The focus is on determining the average force exerted on the ball by the wall during the collision, which lasts for a duration of Δt.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the definition of impulse and its relation to average force and acceleration. There are questions about how to express average acceleration and the implications of the collision being elastic. Some participants explore the relationship between momentum components along the x and y axes and how they relate to the average force.
The discussion is active, with participants attempting to derive relationships between variables and equations relevant to the problem. There is exploration of how to express final velocities in terms of initial conditions and angles, and some participants are questioning how different equations relate to one another. Guidance has been offered regarding the conservation of kinetic energy and the implications of the elastic collision.
Participants note that the answer may not depend on certain variables, such as the final momentum, and there is an emphasis on expressing the final answer in terms of initial conditions and angles. The discussion reflects uncertainty regarding the setup and relationships between the equations involved.
polymerase
A ball of mass m moving with velocity [tex]v_{i}[/tex] strikes a vertical wall. The angle between the ball's initial velocity vector and the wall is [tex]\theta_{i}[/tex] as shown on the diagram, which depicts the situation as seen from above. The duration of the collision between the ball and the wall is [tex]\Delta[/tex]t, and this collision is completely elastic. Friction is negligible, so the ball does not start spinning. In this idealized collision, the force exerted on the ball by the wall is parallel to the x axis.
http://session.masteringphysics.com/problemAsset/1010992/25/MLM_e2.jpg
What is the magnitude F of the average force exerted on the ball by the wall?
How do you even start this question...? i don't know what its talking about. Any comments would be great
What is the definition of impulse?
or rather...
the average force = mass*average acceleration
so what is the average acceleration...
or rather...
ok well impulse is the change in linear momentum so, F[tex]\Delta[/tex]t = m[tex]\Delta[/tex][tex]\stackrel{\rightarrow}{v}[/tex] but in this case it isn't linear...and I am not sure what you mean by average acceleration. but the thing is i was told by my teacher, the answer does not depend on the variable [tex]\Delta[/tex][tex]\stackrel{\rightarrow}{p}[/tex] or m[tex]v_{i}[/tex]
Hmmm... I'm not sure how the answer can't depend on mvi...
Momentum is linear... think of the momentum along the x-axis (perpendicular to the wall), and the momentum along the y-axis (parallel to the wall).
[tex]F_x*(\Delta t) = mv_{xfinal} - mv_{xinitial}[/tex]
[tex]F_y*(\Delta t) = mv_{yfinal} - mv_{yinitial}[/tex], but Fy is just 0 according to the question... so
[tex]0 = mv_{yfinal} - mv_{yinitial}[/tex]
You are also given that the collision is perfectly elastic... therefore the final kinetic energy = initial kinetic energy.
so try to use these 3 equations (impulse in the x-direciton, impulse in the y-direction, conservation of kinetic energy)
to solve for Fx.
to solve for Fx.
How come you need the three equations? why can't you just rearrange the Fx to get you
[tex]F_{x}[/tex]= [tex]\frac{mv_{xfinal} - mv_{xinitial}}{(\Delta t)}[/tex]
note: my mistake, the answer does depend on [tex]mv_{xi}[/tex] but it does not depend on [tex]mv_{xf}[/tex]
so in light of this information, i guess i have to ask you how these 3 equations actually relate to one another.
To get rid of the extra variables... if you just use that equation, you have vf, vinitial, thetafinal, thetainitial...
you should be able to write the final answer just in terms of vinitial and thetainitial...
so is the final answer just F = m[tex]v_{ix}[/tex]/t
not quite... how did you get that?
i don't know...i don't know how to set the three equations equals to one another...
we'll start with this one:
[tex]F_x = \frac{mv_{xf} - mv_{xi}}{(\Delta t)}[/tex]
write vxf in terms vf and thetaf... write vxi in terms of vi and thetai... vf is the magnitude of the final velocity... vi is the magnitude of the initial velocity. vxf = -vfsin(thetaf) (because it is going towards the left)
[tex]F_x = \frac{-mv_{f}sin(\theta_{f}) - mv_{i}sin(\theta_{i})}{(\Delta t)}[/tex] (1)
KEfinal = KEinitial
(1/2)mvf^2 = (1/2)mvi^2
gives
vf = vi.
next equation:
[tex]0 = mv_{yf} - mv_{yi}[/tex]
so
[tex]0 = v_{yf} - v_{yi}[/tex]
[tex]v_{yf} = v_{yi}[/tex]
[tex]v_fcos(\theta_f) = v_icos(\theta_i)[/tex]
using vf = vi from the kinetic energy conservation equation, we get:
[tex]v_icos(\theta_i) = v_icos(\theta_i)[/tex]
[tex]cos(\theta_f) = cos(\theta_i)[/tex]
hence [tex]\theta_f = \theta_i[/tex]
So the point of all this was to show that vf = vi and [tex]\theta_f = \theta_i[/tex]
what do you get when you plug these 2 into (1)
KEfinal = KEinitial
gives
vf = vi.
next equation:
so
So...final answer is F = [tex]\frac{-2msin\theta_{i}v_{i}}{(\Delta t)}[/tex] ?
Yes, but since they only want the magnitude you'd leave off the minus in the final answer.
thanks you thank you thank you
12K
  • · Replies 22 ·
  • · Replies 24 ·
