Measuring the wavelength and position of a photon
The problem involves measuring the wavelength of a photon and determining the minimum uncertainty in its position based on that measurement. The subject area pertains to quantum mechanics, specifically the principles of uncertainty and wave-particle duality.
  • The original poster attempts to relate the uncertainty in momentum to the uncertainty in position using the uncertainty principle. They express uncertainty in wavelength and seek to connect it to momentum. Other participants discuss the relationship between energy and momentum for a photon, referencing relevant equations.
Participants are exploring the relationships between wavelength, energy, and momentum. Some guidance has been offered regarding the equations involved, and there appears to be a productive exchange of ideas, though no consensus or final solution has been reached.
The original poster's approach relies on the accuracy of the wavelength measurement and the uncertainty principle, which may imply constraints on the assumptions made about the photon’s properties.
zing478
A wavelength measurement gives Lambda= 6000 x 10^-10m with an accuracy of one part in a million. What is the minimum uncertainty in the position of the photon?
deltaP*deltaX > h/4pi
p = h/lambda
In order to solve, I know deltaP has to be expressed in terms of deltaLambda. Delta lambda is (6000 x 10^-10)(1 x 10^-6) = 6 x 10^-13.
delta P = dp/dLambda * deltaLambda
I'm not sure how to solve this relationship to get an expression for deltaLambda, to plug back into the original
deltaX > h/(4pi)(deltaP)
Once I get the expression for momentum in terms of lambda, I think I just sub it back in and solve for deltaX.
Any help? or have I done anything wrong so far?
Ok - One has [itex]\Delta\lambda[/itex], from which one can obtain [itex]\Delta[/itex]E.
What is the relationship between E and p for a photon?
Well, E = hc/[tex]\lambda[/tex]
From de Broglies wavelength equation,
[tex]\lambda[/tex] = h/p
so here [tex]\Delta[/tex]E=[tex]\Delta[/tex]pc
So to find the uncertainty in position, I have [tex]\Delta[/tex][tex]\lambda[/tex], change that to [tex]\Delta[/tex]E. From there I can get [tex]\Delta[/tex]p, and
[tex]\Delta[/tex]x = h/4[tex]\pi[/tex][tex]\Delta[/tex]p
Where [tex]\Delta[/tex]x is the minimum uncertainty in position?
Does that make sense?
Yes. That would do it.
Thanks for the help!
