Rotational Kinematics: Finding KE in SR
The discussion revolves around the kinetic energy of rotating objects in the context of special relativity, exploring how to derive a formula analogous to the classical kinetic energy expression for spinning bodies. Participants engage with both theoretical derivations and specific cases, such as a uniform disk, while grappling with the complexities introduced by relativistic effects.
  • One participant states the classical kinetic energy formula for a spinning object and seeks a relativistic equivalent.
  • Another suggests using a "relativistic" moment of inertia and mentions deriving an expression for the kinetic energy of a rotating disk that aligns with the non-relativistic case to first order.
  • A participant explains that the simplification seen in Newtonian mechanics does not carry over to special relativity, indicating a more complex relationship for rotational kinetic energy.
  • Several participants discuss the challenges of separating angular velocity from distance in the context of special relativity, particularly when considering uniform density disks.
  • One participant proposes a method for deriving the kinetic energy using integrals and the relativistic factor gamma, while another questions the treatment of rigidity in the derivation.
  • There is a mention of a potential application of relativistic moment of inertia in explaining the spin of the electron, referencing a specific book that discusses this concept.
  • Another participant warns about misconceptions surrounding relativistic spinning objects, referencing a previous discussion on the Ehrenfest paradox.
Participants express various viewpoints and approaches to the problem, with no consensus reached on a definitive formula or method for calculating relativistic rotational kinetic energy. Disagreements arise regarding the treatment of assumptions, such as rigidity and the nature of the system being analyzed.
Participants note limitations in their assumptions, such as the treatment of rigidity and the uniform density of the disk, which may affect the validity of their derived expressions. The discussion also highlights the complexity of integrating relativistic effects into classical mechanics.
FulhamFan3
Everyone that's taken basic physics know that the kinetic energy of a spinning object with no translational velocity is
KE=(1/2)Iw^2.
where I is the moment of mass and w is the angular velocity. I've been trying to find a similar formula incorporating special relativity but the math is more challenging than I thought. Does anybody have an answer to this?
Not off the top of my head, but I would assume that you could use a "relativistic" moment of inertia:
I = I(ω).
I'll see if I can come up with anything in the next couple o' whiles or so.
EDIT:
Alrighty then. I did a derivation for the kinetic energy of a rotating disk and got an expression. It agrees to first order with the non-relativistic expression (I think; I'll leave it to you to double check the expansion of the natural log and then let me know). Did you want something that has the same form as the non-relativistic expression? If so, I don't think I can help you.
You get such a simple equation from Newtonian mechanics because of the form the Newtonian kinetic energy equation takes. The Kinetic energy of the body in its center of momentum frame is
[tex]KE = \Sigma (1/2)m_{i}v_{i}^2[/tex]
When all the center of momentum frame motiom is the same angular motion this simplifies as
[tex]KE = \Sigma (1/2)m_{i}r_{i}^{2}\omega ^2[/tex]
[tex]KE = (1/2)[\Sigma m_{i}r_{i}^{2}]\omega ^2[/tex]
[tex]KE = (1/2)I\omega ^2[/tex]
For special relativity it would be
[tex]KE = \Sigma (\gamma_{i} - 1)m_{i}c^2[/tex]
Even if all the motion is the same angular motion you see that there is no general way to separate the angular velocity terms from the distance terms to yeild a similar simplification. So this as complicated as the sum is must remain is the SR expression for rotational kinetic energy.
instead of a general espression like "I" how about just a disc with uniform density and radius r.
turin: in your formula what is z and p
If all particles it is comprised of move at the same angular velocity then the integral yields:
[tex]KE = \sigma \pi r^{2}c^{2}[2\frac{c^{2}}{r^{2}\omega ^{2}}(1 - \sqrt{1 - \frac{r^{2}\omega ^{2}}{c^{2}}}) - 1][/tex]
Good luck separating the distance information from the angular velocity into a separate factor you may call the "moment of inertia".
ok, now that we have a forula can I see how you derived it?
Take the equation I gave you:
Rewrite as an integral
[tex]KE = \int_{0}^{r} [\gamma (r) - 1]c^{2}\sigma 2\pi rdr[/tex]
where [tex]\gamma (r) = \frac{1}{\sqrt{1 - \frac{r^{2}\omega ^{2}}{c^{2}}}}[/tex]
and do the integration.
The formula is for a uniform, perfectly rigid, extremely flat cylinder (disk). Δz is the height of the cylinder (thickness of disk). ρ with the ~ over it is the proper mass density of the cylinder (disk).
Of course since there is no absolute perfect rigidity in special relativity you really had to choose a frame according to which it remained of uniform density. In essence you are doing the same thing as I did except I chose a different behavior for my [tex]\sigma[/tex]. I chose for my [tex]\sigma[/tex] to be uniform with respect to the inertial frame for which it spins without translation.
DW,
Actually, I don't know how to treat the rigidity issue, so I ignored it. I assumed a T00 = ρproper c2 γ2, and then integrated that over the volume (area, actually) of the disk, assuming that the area of the disk would not change. I appologize for not listing this as an assumption. I assumed that, since the motion was entirely transverse, the radius of a given element of the disk should not change. Of course, this probably induces a stress, but I assumed that the induced stress would only show up in the Tij components, and since I considered only the T00 for the energy, I shouldn't have to regard the induced stress.
The way I would do the problem is to start with the object at rest in an inertial reference frame, with the origin at the object's center of inertia. (Do I assume correctly that the spin axis is through the center of inertia?) Then impart an angular velocity to the object d[itex]\omega[/itex]. Calculate the energy using DW's formula. That would give us an equation relating the incremental energy to the incremental angular velocity. That can be integrated . . .
outandbeyond2004 said:
... impart an angular velocity to the object d[itex]\omega[itext]. Calculate the energy using DW's formula. ... That can be integrated . . .[/itex]
[itex]If you use DW's formula, I think you would first need to differentiate wrt ω to do what your doing. That would give you dKE/dω. Then, incrementing by dω would give you an increment of dKE. Putting this in an integral would give you integral of dKE = KE. Am I looking at the wrong DW equation?[/itex]
I wonder whether you shall treat this problem separately in a microscopic environment or a macro environment.
In a microscopic environment, I seem to see that a rotational system forms a very stable motion. If we try to assume a set of even distributed matter fields Phi_i and with rotation as Killing vector fields, a rotation can be seen as a symetric motional system, will that lead to a rule such that in this system, it's stable enough so that its motion is conserved just like a linear motion.
In a macroscopic environment, there is no true even-districute matter field. The rotational system is unstable and will continuously tend to reform into a more stable motion system.
There is an important application of the relativistic moment inertia.
Macgregor, in his book, The enigmatic electron, has shown that the moment of inertia of a sphere rotating at its maximum velocity, that is, the speed of light at the equator, is 1/2mr^2. This result explains very simply why the spin of the electron is 1/2.
Warning: necropost!
BJ, resurrecting long-dead threads can cause confusion for frequent posters so it is frowned upon at PF.
bjschaeffer said:
There is an important application of the relativistic moment [of] inertia.
Oh wow... you just reopened a gaping can of big fat wriggling carnivorous flesh-feeding maggots. Earlier this year pervect, myself, and Greg Egan engaged in a long thread on the so-called "Ehrenfest paradox", which concerns the relavistic spinning disk but which is also relevant for any relativistically spinning object. From this thread it should be evident that there are numerous common misconceptions even concerning rotation in flat spacetime, which take time and effort to overcome (not to mention mastery of modern computational tools; see Poisson, A Relativist's Toolkit). I would characterize one theme of this long discussion as "anyone who says 'It's perfectly simple' is talking like a d--n f--l'!", if I might so express it.
Well, there are many claims that of the form "suggestion S explains mysterious datum M". The problem is usually that S conflicts with A, B, ... L.
The book you mentioned, M. H. MacGregor, The Enigmatic Electron, Kluwer, 1992, concerns a classical model of the electron and therefore could be unkindly described as belonging to "the literature of the anachronism". See the https://www.amazon.com/dp/0792319826/?tag=pfamazon01-20 from the publisher. It seems fair to say that suggestions that the electron can be well-modeled using Reissner-Nordstrom or Kerr-Newman solutions are somewhat notorious in gtr. Someone has been pushing fringe to cranky views for quite some time over at this WP article, which tends to be rather misleading as a result. I see that recent versions mention the book you cited.
While I don't have access to that book, from what I have been able to see online at google books, I don't believe the result. But it's good to have a definite source for where this idea came from, even if it is from a necropost.
The problem is that the momentum per unit volume of an object under stress is not equal to the relativistic mass times the velocity. Thus integrating the relativistic mass will not give a correct value for the relativistic moment of inertia tensor, because one cannot compute the relativistic momentum from density * relativistic mass * velocity.
See for instance Rindler, "Intro to special relativity", second edition, pg 132, eq (45.9)
The x component of the momentum density for an object under stress (with a stress energy tensor in its rest frame of [tex]t^{ij}_0[/tex] is
[tex]g^1 = \mu \gamma^2(\mu) \left( \rho_0 + t^{11}_{0}/c^2 \right)[/tex]
Here [itex]\rho_0 c^2 = t^{00}_0[/itex] and the object is moving in the x direction with v/c = [itex]\mu[/itex].
Thus we see that stress in the rest frame of the object affects its momentum density, an example of how energy and momentum intermix in SR.
While some detailed work has been done on the relativistic ring and hoop that I believe is more likely to be correct, it unfortunately has *not* been peer reviewed. I'll send you a link via PM to the webpage that I believe is most likely to be approximately correct even though it hasn't been peer reviewed. (I don't want to be mysterious - we've recently tightened up our policy on links to webpages, which is why I'm not posting it).
I will see for instance Rindler later. Please find below the complete calculation and let me know what is false in it.
MacGregor assumes that the velocity at the equator of the spherical electron is the velocity c of light. Let us compute the observed mass of a filled sphere of radius R in relativistic rotation with its axis at rest. [itex]\rho_0[/itex] is the specific mass on the axis where the matter is at rest. The distance to the axis is r. The height of an elementary cylinder of thickness dr is h. The linear velocity of rotation is v=ωr=(c/R)r (=c on the equator). We have then
[tex]m=\int_0^R\rho_0(r)2\pi(2h)rdr<br /> =2\pi\rho_0 R^2 \int_0^R\frac{2\sqrt{R^2-r^2}}{\sqrt{1-\frac{(\omega r)^2}{c^2}}}d\frac{r^2}{2R^2} <br /> =2\pi\rho_0 R^3 \int_0^R\frac{\sqrt{1-\frac{r^2}{R^2}}}{\sqrt{1-\frac{c^2 r^2}{R^2 c^2}}}d\frac{r^2}{R^2} <br /> =2\pi\rho_0 R^3 \int_0^Rd\frac{r^2}{R^2}=2\pi\rho_0 R^3[/tex]
The same calculation may be done for the moment of inertia of the sphere:
[tex]I=\int_0^R r^2 dm=\int_0^R r^2\rho_0(r)2\pi(2h)rdr<br /> =2\pi\rho_0 R^3 \int_0^R\frac{2\sqrt{1-\frac{r^2}{R^2}}}{\sqrt{1-\frac{r^2}{R^2}}}d\frac{r^4}{4R^4} <br /> <br /> =\pi\rho_0 R^3 \int_0^R d\frac{r^4}{R^4}=\pi\rho_0 R^5=\frac{1}{2}mR^2[/tex]
The Einstein-Planck relationship gives the proper rotational frequency of the electron. This implies that the Einstein-Planck frequency be the same as the rotational frequency of the electron. It is of course a very simple hypothesis:
[tex]\omega=2\pi\nu=2\pi\frac{mc^2}{h}[/tex]
Knowing the rotational frequency, we are able to compute the radius of the electron:
[tex]R= \frac{c}{\omega}=\frac{\hbar}{mc}=R_C[/tex]
[itex]R_C\[/itex] is the Compton radius, the same appearing in the Klein-Gordon equation, and, of course in the Compton effect. MacGregor obtains then the intrinsic angular momentum of the electron :
[tex]L=I\omega=\frac{1}{2}mR_C^2\omega=\frac{1}{2}mvR_C=\frac{1}{2}mc\frac{\hbar}{mc}= \frac{1}{2}\hbar[/tex]
in accord with the observation.
Usual quantum mechanics is unable to get such a result with understandable calculations.
This equation appears to be based on finding the relativistic mass, which if I've understood the book's symbology correctly, the author calls [itex]\rho_0(r)[/itex] as a function of r.
Unfortunately, as I noted earlier:
The correct formulation for the i'th component of momentum in flat space-time is
[tex]P^i = \int T^{0i} dV[/tex]
where [tex]T^{ij}[/tex] is the stress-energy tensor. The 0'th component of the momentum is the energy.
This is based on the fact that one of the interpretations of the stress-energy tensor is that [itex]T \cdot u[/itex] gives the density of energy-momentum in a region, where T is the stress-energy tensor and u is the 4-velocity, see for instance MTW's "Gravitation". (You'll probably find similar remarks in Rindler as well with different notation.)
To deal with spherical coordinates in flat-space-time it might be useful to note that one would more generally write:
[tex]P^i = \int \sqrt{\left| T^{0i}\,T_{0i} \right| }\, dV[/tex]
(I believe this is correct, but it's from fallible memory, not directly from a textbook).
The issue of how to deal with non-flat space-times gets much more involved, but hopefully we don't need to get into that. I'll just point out that one needs certain preconditions to even *define* the total energy or total momentum in a non-flat space-time.
Because the stress terms in the stress-energy tensor do affect the momentum, one would need a complete material model, including the stresses, to find the answer. The issue is complicated by the non-existence of a Born-rigid spherical spinning body, see for instance the sci.physics.faq, so it's not clear that the notion of a rigid sphere spinning at light speed at its periphery makes any physical sense.
See The rigid rotating disk in relativity for a popular discussion and some references. The result for the non-existence of a spinning Born-rigid sphere is due to Ehrenfest, and is the well-known Ehrenfest paradox which Chris Hillman talked about.
The associated faq entry is:
Ehrenfest noted that a disk cannot be brought from rest into a state of rotation without violating Born's condition. Integrating tau out of Born's condition, we see that infinitesimally close particles must keep the same proper distance. So in the original rest frame, they suffer Lorentz contraction in the transverse direction but none in the radial direction. The circumference contracts but the radius doesn't. But in the original rest frame, the circumference is a circle, sitting in a spatial slice (t=constant) of ordinary flat Minkowski spacetime. In other words, we would have a "non_Euclidean circle" sitting in ordinary Euclidean space. This is a contradiction.
The formula by Rindler is applicable only if the mechanical properties of the material making the electron are known. This is not the case.
The centrifugal acceleration, [itex]\omega c\simeq 10^{28}[/itex] is an enormous quantity. No macroscopic material resists such stresses. The strength of elementary particles needs a different approach and the point is that the electron is not broken simply because it exists. The use of elasticity theory is a nonsense for the electron sphere.
The calculation of MacGregor is stationary, not transitory and purely geometric. The process of creation of the spin is unknown. It is possible to compute without using the mass, with only the volume depending of the radius. The calculation is valid only for an electron at low linear velocity so that there is only one frame which is the frame centered at the center of the sphere. The Ehrenfest paradox concerns the problem of accelerating an electron from zero to a given rotational velocity. This problem is not only very complicated, but unrealistic because it will probably never be possible to rotate at will an electron at a given rotational velocity.
I agree that one needs to know the mechanical properties of the material to use the formulas that I've given, and that the mechanical properties of the electron (if the electron can even be understood in this manner) are not known.
I doubt that the formula given by MacGregor and the one given by the references I quoted can both be correct if applied to a material whose mechanical properties are known, because one formula has a result which depends on the state of stress, and the other formula ignores stress.
I would tend to agree that the electron couldn't possibly be made out of anything resembling a normal material, which makes it hard for me personally to get very comfortable with MacGregor's theories.
However, addressing MacGregor's theories as a whole is not something that I'm personally particularly interested in. In any event, discussion of MacGregor's theories would seem to be best done in some other forum, as it doesn't seem particularly relevant to special or general relativity or to the now departed OP's question.
What I can talk about is not MacGregor's theories, but rather the mechanical properties of continuous media according to relativity, which I have done.
I'll add that if one applied MacGregor's formula to calculate the moment of inertia of a star, I would expect that one would not come up with the standard answers given by the literature, for instance (from a google search)
http://arxiv.org/abs/gr-qc/0504020v1 (to first order only)
http://www.aanda.org/index.php?option=article&access=standard&Itemid=129&url=/articles/aa/full/2001/23/aa10321/aa10321.right.html
The problem of the electron is very simplified because [itex]\sqrt{R^2-r^2}[/itex] disappears in the integral when the equatorial velocity of the electron is the speed of light. For a star or any elastic elastic material, the problem may be solved numerically as shown by Wen et al and even analytically but approximately by Egan.
The « modern » quantum mechanics people assume that the electron’s radius is zero. But where is its mass ? The spin is assumed to be a purely quantum mechanics concept. This is a typical scholastic answer from the middle ages.
I have heard that before, but never understood what it means. I thought that in some sense the electron was not a little sphere or point-mass "orbiting" a nucleus, but instead that it was spatially extended rather indefinitely. I understood that this was not considered just difficulty in knowing where the point-mass was, but that the behavior simply can't be described as a point-mass anywhere. It really behaves as a larger entity. I don't have much QM background, so please correct me if I am mistaken, but that was my impression.
In fact scientists do not know the size of the electron; it should in between zero, [itex]10^{-19} m[/itex] (maximum resolution of high energy accelerators), [itex]10^{-15}[/itex] m (so called classical radius) and [itex]10^{-12}[/itex] m (so called Compton radius).
So then it really is a small little speck orbiting the nucleus? Then why doesn't it radiate as it accelerates around the nucleus? That is why I thought it made more sense for it to be "smeared out"
This thread has drifted away from relativity into Quantum mechanics, and has been hijacked to boot, so I'm going to lock it.
Standard QM terminology is to refer to an electron orbit as an electron orbital, because it's not quite the same thing as an orbit. For instance, some orbitals have zero angular momentum.
Whether or not the electron "really is a speck" is mostly a question of philosophy and interpretation, (as one can guess from the use of the word "real"), and is best taken up in another forum.
  • · Replies 87 ·
  • · Replies 20 ·
  • · Replies 25 ·
