Solving a Fairly Simple Gravity Problem with Negligible Air Resistance
  • Thread starter Thread starter PiratePhysicist
    Gravity
The discussion revolves around a physics problem involving a particle falling to Earth from a significant height, specifically addressing the time it takes to traverse the first half of the distance compared to the total fall time. The problem is situated within the context of gravitational forces and motion under gravity, neglecting air resistance.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore various mathematical approaches, including the use of conservation of energy and differential equations. Some question the validity of the assumption that the time to fall the first half is 9/11 of the total time, suggesting it may stem from a misunderstanding or misstatement in the problem.
The discussion is ongoing, with participants providing insights and alternative perspectives on the calculations involved. Some have offered guidance on the mathematical derivations, while others express skepticism about the original time ratio stated in the problem.
There is mention of potential confusion regarding the problem's parameters, particularly the 9/11 time ratio, which some participants believe may not align with standard results from similar gravitational problems. The original poster references a textbook for the stated value, indicating a reliance on external sources for the problem's setup.
PiratePhysicist
I named my original post poorly, so this one is meant to just rename it, my work so far can be found in https://www.physicsforums.com/showthread.php?t=191219
1. Problem: A particle falls to Earth starting from rest at a great height (may times Earth's radius ). Neglect air resistance and show that the particle requires approximately 9/11 of the total time of fall to traverse the first half of the distance.
2. Homework Equations :
[tex]F=\frac{-G M_e m}{r^2}[/tex]
3. Attempt at the solution:
I think what you need to do is, at this point:
[tex]v^2=2G M_e ( \frac{1}{r}-\frac{1}{r_0})[/tex]
let r0 = infinity...
then continue from there.
although your derivation using separable diff. eq. was all correct... you can use conservation of energy to do that, unless you haven't covered energy yet...
Nope, tried something similar (redefined axises so [tex]r_0[/tex] was 0), here's what happens:
[tex]\frac{dr}{dt}=\sqrt{\frac{2 G M_E}{r}}[/tex]
[tex]\sqrt{r}dr=\sqrt{2 G M_E}dt[/tex]
[tex]\frac{2}{3}r^{\frac{3}{2}}=sqrt{2G M_E}t[/tex]
[tex]t=\frac{2}{3}\sqrt{\frac{r^3}{2GM_E}}[/tex]
So if you take the ratio of t(1/2r) and t(r) you get
[tex]\frac{\frac{2}{3}\sqrt{\frac{(\frac{r}{2})^3}{2GM_E}}}{\frac{2}{3}\sqrt{\frac{r^3}{2GM_E}}}[/tex]
Which boils down to
[tex](1/2)^\frac{3}{2}[/tex] which is equal to .353535... not .8181818181
Won't there be a non-zero integration constant to be evaluated?
The original differential equation
describes an outbound trajectory, since the right-hand side is positive. Infall should require the insertion of a minus sign, no? In any case, dr/dt is only zero according to this equation for r -> infinity; then you have a separate can of worms in describing when you have fallen halfway from infinity. If you start from a finite distance out (or time-reverse the path, start from the Earth's surface, and look at the times when the particle reaches (r0/2) and r0, the integration is incomplete as it stands...
Erm, my long drawn out derivation, was meant to show that the take to infinity assumption doesn't work, but your explanation works better and doesn't require lots of LaTeX ^_^
So anyone else have any suggestions?
Something seems suspect about that 9/11 value. You can treat the "radial infall" problem using Kepler's Third Law on what are called "degenerate orbits".
Compare the fall from r0 with a fall from (r0/2) by treating each as having a pericenter at r = 0 and the apocenters at r0 and (r0/2), respectively. Then the "semi-major axes" of these degenerate ellipses are a1 = (r0/2) and a2 = (r0/4). The respective times to reach r = 0 are the half-periods of these "orbits"
T1 = (1/2)·sqrt[ {4·(pi^2)/GM} · (r0/2)^3 ] and
T2 = (1/2)·sqrt[ {4·(pi^2)/GM} · (r0/4)^3 ] ;
in other words, basically what you found by integrating the energy result (and starting from the gravitational force equation takes you to the same place).
The ratio of the infall times is T2/T1 = (1/2)^(3/2) = 0.3536... , as you already found. (This is a standard astrophysical exercise.) The time to fall the last half is 0.354 of the time to fall the full distance, so the time to fall the first half is about 0.646 of the total infall time.
That former value is very close to 4/11 = 0.363636... , which makes me wonder if there was a handwriting issue and whether the writer confused the statement of the problem. (This would make the answer to the stated question about 7/11 of the total time.) I think your derivation is basically correct; the 9/11 didn't sound right to me from the start, but I thought maybe I was recalling something incorrectly...
The 9/11 number comes from the book (Classical Dynamics of Particles and Systems 5th Ed Thornton and Marion)
  • · Replies 47 ·
  • · Replies 33 ·
  • · Replies 16 ·
