Bug lands on a frictionless sphere. Show that the Bug leaves head when
The problem involves a bug that lands on the frictionless surface of a spherical head and begins to slide down. The objective is to demonstrate that the bug leaves the surface after dropping a vertical distance equal to one-third the radius of the head.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the conservation of energy and the forces acting on the bug as it slides down the sphere. There are attempts to relate gravitational potential energy and kinetic energy, as well as considerations of the normal force and its relationship to centripetal force. Some participants express confusion about the correct height at which the bug leaves the surface and how to apply conservation laws effectively.
There is an ongoing exploration of the problem, with participants questioning the assumptions made about the height at which the bug leaves the surface. Some guidance has been offered regarding constructing diagrams and setting up force balance equations, but there is no explicit consensus on the approach or solution yet.
Participants note the potential confusion regarding the vertical distance the bug falls and its relationship to the radius of the sphere. There are references to the need for clarity on the definitions of forces involved and the geometry of the situation.
gills
A bug lands on top of the frictionless, spherical head of a bald man. It begins to slide down his head.
Show that the bug leaves the head when it has dropped a vertical distance 1/3 the radius of the head.
Not sure. Maybe:
E_f - E_i = 0 since it is conserving energy (no friction)
and/or possibly
F=ma to calculate the normal force = 0 when the bug is 1/3 vertical h down the head somehow?
Well, if i use the E_f - E_i = 0:
If the bug fell R/3 vertical displacement then its height at E_f = (2/3)R
[mg(2R/3) + (1/2)mv^2] - (mgR) = 0 ----->
not quite sure how to prove that the bug drops off the head via this method.
Thanks in advance,
Tom
One has to show that the bug leaves the surface at h = R/3.
At the point when and where the bug leaves the surface the normal (centrifugal) force would equal the component of gravity (centripetal force) pointing inward.
Construct a diagram which shows the bug starting at top of a sphere at R, and then it falls to h.
Determine the force balance equation and use the conservation of energy remembering the bugs starts with zero KE but with some GPE with respect to where it leaves the surface.
Would setting h = R/3 be incorrect because it mentions in the problem that it falls that vertical distance then falls, so it falls off the head at (2/3)R.
I'm confused on how to use the conservation laws with Normal force and the component gravity force of the bug. Any help would be great.
i could use a little help on this one too if anyone's around...
I don't understand this myself. I've looked at it for ages, and it just doesn't seem to make sense to me at all.
I would like some help as well, lol.
Yea, that link helped a little, but I'm still a little confused.
Sorry for the confusion. That is h measured from the top of the sphere rather than the horizontal diameter.
This should help
http://img166.imageshack.us/img166/6581/particleonspherepy9.jpg
images by Gert Hamacher
One needs to find the relationship between the change in GPE (=mgh) and kinetic energy (using the tangential speed v), and using the expression for centripetal acceleration and geometry, find the relationship between h and R when the force on the sphere is zero, i.e. just before the mass leaves the surface.
  • · Replies 27 ·
9K
  • · Replies 97 ·
