Regarding Total Internal Reflection
Total Internal Reflection occurs at the optical interface between crown glass and ethanol when light transitions from a medium with a higher index of refraction (crown glass, n=1.52) to one with a lower index (ethanol, n=1.36) at an angle greater than the critical angle of 63 degrees. When white light enters ethanol from crown glass at an incidence angle of 60 degrees, the angular spread between red and violet light is calculated to be 13 degrees. The Brewster angle for light traveling from ethanol back into crown glass is significant as it indicates the angle at which reflected light is completely polarized.
  • Understanding of optical refraction and reflection principles
  • Familiarity with Snell's Law and critical angle calculations
  • Knowledge of light polarization concepts
  • Ability to interpret and create light-ray diagrams
  • Study Snell's Law and its applications in optical interfaces
  • Learn about Brewster's angle and its implications in optics
  • Explore the concept of light polarization and its practical applications
  • Investigate the behavior of different wavelengths of light in various media
Students and professionals in physics, optical engineering, and anyone interested in the principles of light behavior at interfaces.
nblu
Regarding "Total Internal Reflection"
Hi, and thanks in advance for viewing this post.
I'd like to type out the question first;
Q: Consider the optical interface between crown glass and ethanol.
a) Under what conditions would total internal reflection be possible at this interface?
Illustrate your answer with a light-ray diagram.
b) White light travels from crown glass into ethanol. If the angle of incidence in crown
glass is 60.00 degrees (not sure how to insert degree sign), what is the angular spread
between the red and violet parts of the visible spectrum in the ethanol? Illustrate your
c) Light travels from ethanol into crown glass. What is the Brewster angle in this
situation? Illustrate your answer with a light-ray diagram. What is the significance of
this angle of incidence?
Ok, so I have completed question a) and b). (Still working on c).
Any correction/advice would be greatly appreciated! Thanks again!
Answers:
a) In order for the total internal reflection to occur, the light must enter from higher
index of refraction to a lower index of refraction, which in this case, Crown glass -->
Ethanol. In addition, the incident angle must be greater than the critical angle, which
is 63 degrees.
Calculation:
Crown glass = 1.52 > Ethanol = 1.36
Sinθc = (1.36)(1.00) / 1.52
θc = 63 degrees.
Diagram:
http://img146.imageshack.us/img146/5690/spa0202ux3.th.jpg
b) Calculation
θi = 60 degrees
n1 = 1.520 (for red light in crown glass)
n2 = 1.376 (for violet light in crown glass)
nR = 1.36 = Ethanol
For red light;
(will omit calculation due to complication of work on this thread lol)
sinθR = 75 degrees
For violet light;
sinθR = 88 degrees
θdisplacement = θR(violet) - θR(red)
Therefore, θdisplacement = 88 - 75 = 13 degrees.
Diagram:
http://img513.imageshack.us/img513/3772/spa0201aj8.th.jpg
I apologize for the work not being neat T_T
I'm still working on the question C so i will add to the post when its complete hehe
Thank you very much! again!
There is no problem with this; I haven't checked the calculated numbers, but your logic is correct and if you can work that abacus correctly, I'll assume the numbers are right.
C is the easiest part. Look under polarization.
Thank you Chi Meson, I hope my works get perfect lol :\
and yep, for the part c, I've wrote down how the incident, or the Brewster angle
indicate that the reflected light is completely polarized parallel to the interface.
Thanks again!
12K
