Crystal Vibrations: Impurity in a monoatomic chain
The discussion focuses on solving the equation of motion for a linear monoatomic chain with an impurity, where all atoms have mass M except one with mass m. The correct formulation of the equation of motion is established as m_n \ddot{u_n} = C(u_{n+1} - 2u_n + u_{n-1}). The approach suggested includes using Fourier transforms to transition to k-space, which is expected to simplify the equations and facilitate finding a solution. The importance of proper notation and understanding the nature of the differential equation is emphasized.
  • Understanding of linear differential equations
  • Familiarity with monoatomic and diatomic chains in solid-state physics
  • Knowledge of Fourier transforms and their applications in physics
  • Basic concepts of wave propagation in lattice structures
  • Study the derivation of equations of motion for monoatomic chains
  • Learn about the application of Fourier transforms in solving differential equations
  • Explore the concept of localized wave packets in solid-state physics
  • Investigate the effects of impurities in crystal lattices and their impact on vibrational modes
Students and researchers in solid-state physics, particularly those studying lattice dynamics and the effects of impurities on vibrational properties of materials.
Perses
Hello everyone, I'm a bit stuck on this particular problem and i was hoping somebody could give me a couple tips or hints!
"consider a linear monoatomic chain where all atoms have a mass M except one which has a small mass m. The force constant is C."
First I'm asked to write the equation of motion for the relevant atoms. Then, I'm asked to solve it assuming a displacement function for atom n in the form of
Un = Aexp(-ax)exp(i((omega)t - Kx))
Let the chain be:
vs-2 -- vs-1 --- u --- vs --- vs+1
where u is the impurity
I'm currently lost at the beginning of the problem, finding the equation of motion. What i first thought was to treat this almost like it were the case of a diatomic chain.
Mdvs/dt = C(vs+1 + u - 2vs)
mdu/dt = C(vs-1 + vs - 2u)
however, upon continuing in the problem I'm not sure that this is correct. Could anyone offer any advice as to how i should start this problem?
Your notation is a little distracting. Simply call the displacement of the n'th atom (from its equilibrium position) [itex]u_n[/itex]. Let the impurity be at n=k.
Secondly. you've made a mistake in constructing your equation of motion, which is a second order linear DE (not first order).
See that you should get something more like :
[tex]m_n \ddot{u_n} = c(u_{n+1} -2u_n+u_{n-1})[/tex]
From here, I'm not sure what's the best approach. One possibility is to Fourier transform to k-space and hope the equations become decoupled. Odds are they will. Also, you will likely find that the solution in k-space is the FT of the localized wavepacket provided to you.
  • · Replies 36 ·
