Thread Closed
Two Parallel Wires( in 2 hrs!)
Share Thread Thread Tools
Oct17-07, 02:30 PM   #1
Two long parallel wires are a center-to-center distance of 1.50 cm apart and carry equal anti-parallel currents of 1.80 A. Find the magnetic field intensity at the point P which is equidistant from the wires. (R = 4.00 cm).
2. Relevant equations
[tex] B= \frac{u_{0}I}{2\pi r} [/tex] infinite wire
3. The attempt at a solution
Ok I have been workin this problem for a while.
In terms of vectors, the y's cancel out.
For the X direction I get:
[tex] B_{totalx}=\frac{u_{0} I R}{\pi \sqrt( (d/2)^2 +R^2)}[/tex]
I dont get why I am wrong, I took the sum of the b-fields in terms of vectors.
And no the answer is not 0 T!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Oct17-07, 02:45 PM   #2
Why do you think that the Magnetic field is not zero?
Oct17-07, 02:49 PM   #3
Thats what I thought originally , but it is incorrect.
Oct17-07, 03:03 PM   #4
If they have equal, anti-parallel currents, and it's a point that's equidistance from the wires, then the answer has to be zero. Unless you decide to ignore the fact that magnetic fields are vectors.
Oct17-07, 03:12 PM   #5
Anti-parallel.
Oct17-07, 03:15 PM   #6
Quote by PiratePhysicist View Post
Thats what I used to think too, but when I entered 0 T it is incorrect.
there is something else I am missing.
Oct17-07, 03:50 PM   #7
Quote by TVP45 View Post
Anti-parallel.
got an idea?
Oct17-07, 03:52 PM   #8
Go back and ask your instructor what he means by anti-parallel. It has more than one meaning. It shouldn't but it does.
Oct17-07, 04:00 PM   #9
I agree, word choice could be better.
However I don't have contact with my prof. right now, this assignment is due in an hour.
Oct17-07, 04:02 PM   #10
If I was you I would give your best guess (ignore that you know it's "not right") and argue for points later. Chances are others having the same problem.
Oct17-07, 04:04 PM   #11
perhaps his answer is wrong by mistake? talk to other people in the class
Oct17-07, 04:17 PM   #12
he is not, there is an answer I people got. There is some trick though, but my math tells me otherwise,
Oct17-07, 04:50 PM   #13
Recognitions:
Homework Helper Homework Help
??? The two B fields add up, they don't cancel!!
It's when the currents are in the same direction that the total B field is zero at the point midway between them.
Oct17-07, 05:23 PM   #14
Mentor
Quote by Winzer View Post
Good.
True.
Show how you got that answer--it's not dimensionally correct, for one.
Oct18-07, 06:32 AM   #15
OK, now that I can see your diagram, I see the instructor used anti-parallel in the correct sense.
Thread Closed
Thread Tools
Similar Threads for: Two Parallel Wires( in 2 hrs!)
Thread Forum Replies
Magnetic forces between parallel wires Introductory Physics Homework 7
force between two parallel wires Introductory Physics Homework 1
Parallel Wires Introductory Physics Homework 1
two wires in parallel and capacitence Advanced Physics Homework 1
Parallel wires Introductory Physics Homework 9
