| Thread Closed |
How do I put a Zenith Angle in my calculator? |
Share Thread | Thread Tools |
| Oct19-07, 12:10 AM | #1 |
1.I am given a zenith angle of 73 (degrees) 17'30"
2. How do I compute (2360/5280)times cos(73 degrees, 17'30") with a ti 89 and a regular scientific calculator? 3. The solution is .446 degrees Thank you sooo very much. |
| Oct19-07, 12:52 AM | #2 |
Recognitions:
have a look at this link:
http://id.mind.net/~zona/mmts/trigon.../degMinSec.htm convert to degrees... to convert minutes to degrees divide by 60... so 17' = 17/60 degrees to convert seconds to degrees divide by 3600... 30" = 30/3600 degrees But I don't see where the 0.446 comes from... |
| Oct19-07, 07:13 AM | #3 |
Are you taking astronomy? Is the question about insolation?
Can you give the complete question? |
| Oct19-07, 10:41 AM | #4 |
on most casio and sharp calculators (FX series and DAL series, is what most students use in my part of the world), there is a button that looks like . , ,,
if your angle measurement is set to degrees, you can input DMS measurements like this: 73 (. , ,,) 17 (. , ,,) 30 (. , ,,) and it will do the calculation in DMS. On the casio it returns the andswer in DMS and you must press this button again when it displays the answer to show you in decimal degrees. Hope that helps. I have used a TI89 myself but can't think how it differs. I only have a TI83 to hand and that is very different to a TI89 I think |
| Thread Closed |
| Thread Tools | |
Similar Threads for: How do I put a Zenith Angle in my calculator?
| first angle,third angle projection | Engineering Systems & Design | 28 | ||
| A new angle on the Right Angle Lever Paradox. | Special & General Relativity | 27 | ||
| How does the angle at which a ray of light strikes a prism compare with the angle at | Introductory Physics Homework | 9 | ||
| Zero Launch Angle: Vox and Angle | Introductory Physics Homework | 1 | ||
| Angle, Side, Angle | General Discussion | 5 | ||
