In what direction does a compass needle point?
A compass needle points in the direction of the magnetic field lines at its location, which is toward the magnetic south pole located near the geographical north pole. When a bar magnet is brought near the compass, the needle will point toward the north magnetic pole if the north pole of the magnet is facing it, and toward the south magnetic pole if the south pole of the magnet is facing it. In the northern hemisphere, the compass needle generally points approximately north, while in the southern hemisphere, it points approximately south.
  • Understanding of magnetic fields and poles
  • Basic knowledge of compass functionality
  • Familiarity with geographical and magnetic coordinates
  • Concept of magnetic declination
  • Research the differences between geographical north and magnetic north
  • Learn about magnetic declination and its effects on navigation
  • Explore the principles of magnetism and magnetic field lines
  • Study the behavior of compasses in different geographical locations
Students studying physics, navigators, geographers, and anyone interested in understanding the principles of magnetism and compass usage.
Ryo124
In what direction does a compass needle point? (More than one answer may be true.)
T/F In the direction of the magnetic field lines at the location of the compass.
T/F Toward the north magnetic pole if a bar magnet is brought near the compass.
T/F Toward the south magnetic pole if a bar magnet is brought near the compass.
T/F Approximately toward the north in the northern hemisphere.
T/F Approximately toward the north in the southern hemisphere.
T/F Approximately toward the south in the southern hemisphere.
None.
I put T, T, F, T, F, F however, it is wrong. Can someone help please?
A hint is that the geographical north (above Canada) is the magnetic south.
The geographical south (Antarctica) is the magnetic north.
Makes sense. Thank You.
  • · Replies 31 ·
