Thread Closed
Pressure of Syringe
Share Thread Thread Tools
Oct20-07, 06:35 PM   #1
Pressure of Syringe
A 2.0 mL syringe has an inner diameter of 6.0mm, a needle inner diameter of 0.25mm, and a plunger pad diameter (where you place your finger) of 1.2 cm. A nurse uses the syringe to inject medicine into a patient whose blood pressure is 140/100.
a. What is the minimum force the nurse needs to apply to the syringe?
b. The nurse empties the syringe in 2.0s. What is the flow speed of the medicine through the needle?
2. Relevant equations
P = pgh
0.5pv^2 + pgh + P = constant
Av = constant
P = F/A
3. The attempt at a solution
Using P = pgh, I found the minimum pressure required to inject the medicine to be 18659.2 Pa. I tried to plug that into P=F/A but didn't get the right answer. For a, the answer is supposed to be 0.377N and for b, 20.4m/s. Does anyone know how to get these answers? Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Oct20-07, 10:14 PM   #2
Recognitions:
Homework Helper Homework Help
convert 100mm Hg into Pa...
Then use that in P = F/A, where A is the area of the inner diameter, 6.0mm.
Then use the 0.25mm area to get the flow velocity.
Jun12-09, 01:40 AM   #3
how do you get the flow velocity from the two area's? with out any velocities?
Thread Closed
Thread Tools
Similar Threads for: Pressure of Syringe
Thread Forum Replies
Syringe pump Engineering Systems & Design 10
achieving a negative pressure with a syringe General Physics 12
Syringe Aspiration General Physics 0
Help with syringe pressure and Students T test General Math 1
syringe problem Introductory Physics Homework 0
