Gravity: Is Matter Mostly Empty Space?
The discussion revolves around the nature of gravity, particularly its relative weakness compared to other fundamental forces and the implications of matter being mostly empty space. Participants explore various perspectives on gravitational force, atomic structure, and the interplay between gravity and electromagnetic forces.
  • One participant suggests that gravity's weakness may be due to matter being mostly empty space, using the example of a hydrogen atom to illustrate the vast distances between protons and electrons.
  • Another participant proposes a comparison of the Coulomb force and gravitational force between electrons to highlight the relative strengths of these forces.
  • It is noted that while gravity is the weakest force, it can accumulate over large scales, unlike electrical forces which can cancel out due to charge neutrality.
  • Some participants argue that gravity appears strong on large scales, such as in galaxies, due to the overall neutrality of matter and the inability of electrical forces to accumulate in the same way.
  • A later reply discusses hypothetical scenarios where atoms lack electrons, suggesting that in such cases, electromagnetic interactions would dominate over gravity.
Participants generally agree that gravity is the weakest force but debate the implications of this weakness and the conditions under which gravity appears strong. Multiple competing views on the nature of forces and their interactions remain unresolved.
Participants express varying levels of understanding and familiarity with advanced topics, indicating that some assumptions may be missing or definitions may vary. The discussion does not resolve the complexities of gravitational and electromagnetic interactions.
This discussion may be of interest to physics enthusiasts, students exploring fundamental forces, and individuals curious about the nature of gravity and atomic structure.
BosonJaw
People say gravity is an extremely weak force. Weaker than any of the other three basic forces that govern our universe. Explanations to this have varied in all forms of radical ideas (I'm not saying I outright reject them). But it has always pestered me the idea that perhaps gravity is such a weak force because matter is mostly compiled of empty space. In a hydrogen atom, if the proton were the size of a pixel on your screen, the electron would be about another 50,000 pixels away most of the time...right?. Now imagine if all of that empty space had been compacted with protons. The measure of force relative to density is roughly 5.2 x 10^14 times the magnitude of the original force.
Perhaps I'm missing a concept with my idea here. Mind you I am a physics enthusiast and some of the more advanced topics I am still ignorant to. But I still have the right to ask questions. I hope :smile:
Your ideas, comments, criticisms, or corrections would be much appreciated. :)
look at the forces on an electron, which is not made up of anything else than itself (not as in the case of atoms, where you have 99.999..% nothing). Compare the Coloumb force between two electrons separated 1m and the force of gravity betweem them.
should be a straightforward calculation example for you and it is very illuminating =)
The gravitational force would be larger in your example, BosonJaw, but think about how much much much much MUCH larger the Coulomb force would be (protons have charge)!
But you bring up a very good point: gravity is not weak in the world. After all, we are glued to the Earth, galaxies are held together by gravitational binding energy, black holes have an incredible amount of energy to them, etc. The key point in all of this is that there is no "anti-gravity" but there is "anti-electricity" - that is, charges can cancel but masses will always add up. Therefore on the large scale, gravity is quite strong. But that's only because matter is neutral (same number of electrons as protons) so the even stronger Coulomb force cancels while gravity grows.
Otherwise, the world would look very different! :-)
Well , the gravity force is the weakest of all, but there is a very important property of gravity: it can accumulate while , let say, electrical force can not. As a result, you can not accumulate a bunch made of only negative (or positive) charged particle, while as for gravity you can, "the more, the better", even to an extent of a galaxy or the like.
That just follows from blechman's post, that there are no anti-gravity.
Different range, different level. If you regard the galaxy as a particle, the gravity is strong. Only on the large scale the gravity will show his power.
but if we instead imagined that each atom in a galaxy did not have any electrons, and in another, only the electrons where there; then the electronic interaction would be much much greater ;)
The reason for gravity to dominate over larger distances is due to the over-all neutrality of matter of large objects, since there exists two types of electric charges. So yes in reality gravity dominates over large distances, but still it is a very very weak force.
  • · Replies 28 ·
  • · Replies 22 ·
