How Much Work Does a Non-Ideal Gas Perform During Expansion?
The discussion focuses on calculating the work performed by a non-ideal monatomic gas during expansion from an initial volume of 0.3 m3 to a final volume of 0.44 m3 at a constant temperature of 100 K. The pressure-volume relationship is defined as P = Po(Vo/V)1/2, with Po set at 100,000 Pa and Vo at 0.1 m3. The work done by the gas can be derived from the integral of pressure with respect to volume, applying the given equation to find the specific work output during the expansion.
  • Understanding of non-ideal gas behavior
  • Familiarity with the ideal gas law and its limitations
  • Knowledge of thermodynamic work calculations
  • Basic calculus for integrating pressure-volume relationships
  • Study the derivation of work done by non-ideal gases
  • Learn about the van der Waals equation for real gases
  • Explore thermodynamic cycles involving non-ideal gases
  • Investigate the impact of temperature on gas behavior
Students studying thermodynamics, physicists analyzing gas behavior, and engineers working with non-ideal gas systems will benefit from this discussion.
ODrule
For some particular unusual non-ideal monatomic gas, take the relation beween P and V at some fixed To to be
P = Po(Vo/V)1/2.
Let To = 100 K, Po = 100000 Pa, and Vo = 0.1 m3.
How much work does this gas do if it expands, pushing on a piston, from Vi = 0.3 m3 to Vf = 0.44 m3 at T = 100 K?
Someone please help?
I don't understand non-ideal gases.
Even though you don't know much about non-ideal gases, that doesn't mean you can't do anything here. Give me some of your thoughts on the problem. Here's a hint to get you started thinking:
What is the definition of work done by a gas? This should still apply to this non-ideal gas, correct?
  • · Replies 17 ·
  • · Replies 21 ·
