Graphs of functions of several variables
The discussion revolves around the graph of the function z=xy and its behavior when intersected with the plane y=x. Participants explore whether the resulting curve is a parabola and how it compares to other parabolic forms, particularly z=x^2. The context involves understanding the geometric implications of these intersections in three-dimensional space.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants examine the nature of the curve formed by the intersection of the plane y=x with the graph z=xy, questioning if it is a parabola and how it relates to other parabolas like z=x^2. They also discuss the effects of changing coordinates and the implications of symmetry in the function.
The discussion is active, with participants offering various insights and questioning assumptions about the geometric properties of the graph. Some have suggested visualizing the graph in different coordinate systems to aid understanding, while others are still grappling with the implications of their findings.
There is an ongoing exploration of how the function behaves in different quadrants of the xy-plane and the impact of changing variables. Participants are also considering the implications of the function's behavior as variables approach zero or infinity, as well as the nature of intersections in different planes.
kingwinner
Consider the graph of z=xy.
Choose the section y=x, i.e. intersect the plane y=x with the graph z=xy, I get z=(x)(x)=x^2, with y=x. Now is this a parabola? (note that the curve actually lies on the plane y=x)
If so, why?
Also, is this parabola going to have exactly the same shape as the one parallel to the x-axis?(i.e. z=x^2, y=0)
How is the graph of z=xy going to look like?
I spent an hour thinking of these, but still can't figure it out...
Can someone please help me? I seem to be skewing up geometrically. I can't understand geometry like this...this is driving me crazy
z=0 along the x and y axes. As you've noticed along the line y=x, the cross section is parabolic with z positive. Along x=-y it's parabolic with z negative. To picture it just think of z as height above (or below) the xy plane. I'm not sure exactly what the question is beyond that.
Also think about symmetries. What happens to the product in each quadrant of the xy-plane? What happens if you change the sign of either x or y?
How does the product behave as either variable or both approach zero? approach infinity?
Say if we consider the xz-plane only, then z=x^2 is surely a parabola (*).
But on the plane y=x, is z=x^2 going to be the projection of the above parabola (*) on the plane y=x? If this is the case, then this curve and the above parabola (*) won't be the same, right? Would it even look like a parabola at all?
or
On the plane y=x, is z=x^2, imagine revolving the parabola (*) until we hit the plane y=x, and then take the intersection of this curve (same shape as parabola (*) ) with the plane y=x[/color], is this the curve of intersection of the plane y=x with the graph z=xy? If this is the case, then certainly this curve and the above parabola (*) have the same shape.
Nooooo. It's not a surface of revolution. In the xz (that's y=0) plane it's zero. Look at your equation.
To be on the xz-plane, wouldn't y have to be zero?
It will be z = x^2 = y^2. Since both advance linearly along that plane, z would follow a parabolic curve.
What would happen on the yz-plane? on the plane y = -x ?
While we're about it, what would the equation look like on the plane y = kx , k real?
z=xy=[(x+y)^2-(x-y)^2]/4
change coordinates x'=x+y, y'=x-y
z=(x'^2-y'^2)/4
Sorry, but I didn't mean the surface...
I actually mean:
On the plane y=x, is z=x^2, imagine revolving the parabola (*) until we hit the plane y=x, and then take the intersection of this curve (same shape as parabola (*) ) with the plane y=x, is this the curve of intersection of the plane y=x with the graph z=xy?
Sure.
Why?
Sorry, but I don't understand what you mean by advancing linearly along plane...
z=(x'^2-y'^2)/4
What does this imply? I can't see what this is heading into...sorry
KW-
Since z=(x'^2-y'^2)/4
where x'=x+y, y'=x-y
It shows that z can be written as a parabolic along directions x' and y', which are at right angles. Note that the x' axis is the diagonal between the x and y axes and y' is between the x and -y directions.
It's a lot easier to sketch the function doing it this way. Try sketching it in the x' y' axes using z=(x'^2-y'^2)/4 and then draw in the x y axes, where x=(x'+y') /2, y=(x'-y')/2
OK, I see what you are saying now, it's graph is a hyperbolic paraboloid.
But, I am still not understanding how the intersection of the plane y=x with the graph z=xy would look like...
Why?
When I was saying here is what christianjb is referring to by rotating the coordinate system 45º: on the line y = x, x and y advance at the same constant rate (what I meant by 'advancing linearly' -- I'm sorry if that wasn't the best choice of words). Since y = x,
whichever coordinate you look at, the value of z increases quadratically. So the cross-section of the surface z = xy on that plane is an upward-facing parabola starting from z = 0 at the origin. That parabola is z = x^2 or z = y^2 .
If you choose a different cross-section using y = kx , you get z = x·(kx) = k·x^2 , which is just a parabola starting at z = 0 at the origin and growing at a different rate. All the cross-sections made by vertical planes rotated at various angles to the x-axis are parabolas, including the "degenerate" parabola z = 0 on the yz-plane.
The exception is that there is a "break" on the xz-plane, where the vertical plane is now perpendicular to the second and fourth quadrants of the xy-plane, corresponding to k < 0. The product abruptly switches from being positive to negative on either side of the xz-plane, with the cross-section again being "degenerate" for y = 0.
